| In midst of DIY kitchen reno and slowly going thru recessed lighting posts.
How do people pick 4" versus 5" versus 6" cans? I'd come to the conclusion that 4" meant small cans taking small 50W PAR20 and 5" meant 75W PAR30, i.e. similar beam angles (similar spacing) and different foot candles. Some posts mention they have mixed 4" and 5" in their kitchen. What are they using for what? and what's the decision process? Large cans for high ceilings or what? I've found that self-taught means you can know some complicated stuff and be completely ignorant of some basic stuff. I keep thinking I'm missing something here :) TIA |
| If a fixture says it takes 75W PAR30, can I instead use a 50W PAR20? Only a few Halo trims specify both sizes. I'd assumed bulbs are non-interchangeable due to different physical configurations, but then texasredhead has mentioned there's an adjustment to lower the bulb. |
| Lots of missing info. If you are trying to design your own lighting in the middle of a remodel but asking these types of questions you might want to check out a book at the library. Attached is an online class. I hope the link works... There would be too much to type to explain all that you need to learn fast. |
Here is a link that might be useful: More help
- Posted by normclc (normb@norburn.com) on Sun, Jun 7, 09 at 19:27
| The size of the recessed can is determined by the light bulb(lamp)that you want to use. As a rule the 5" is for 75par30 or less, used for general lighting. The 6" is for 90par39 lamps that you would neec on ceilings over 15'. The 4" is usually used for 50mr16 (or less) 12 volt lamps , used to direct light on art or task areas . There is a inferior quality 50par20-120volt lamp that is used strictly to save money, but , because of it's relatively short life, extremely narrow beam spreads, and lower quality of light output, it costs you more in the long run. Use 5" cans with 50 or 75par30/fl for general lighting, and 50mr16's for accent or task lighting. It is entirely acceptable to use 2 different can sizes in the same room. |
| Thanks normclc – from a really vague question you’ve read my mind and responded with extremely concise answers. The big-box stores are really pushing those "inferior quality 50par20-120volt lamp kits". A neighbor had these installed and I wasn’t impressed. You’ve explained to me why I wasn’t impressed. I’ve been studying the lamp data on the junolightinggroup.com. Taking your comments and re-looking at the tables, watt for watt, the par30 is just brighter, little wider beam spread, and has a longer rated life. So the 4" line voltage cans using par20 are a poor choice compared to the 5" cans using par30. I only have 8’ ceilings so really big lamps (in a big 6" can) aren’t required. Could you explain why you spec’d the low voltage mr for task lighting? I’m putting recessed lights in a small 12’ x 12’ kitchen over the counter edge as task lighting. There’s a pendant globe (100W) over the kitchen table for general lighting. The counters are 5’ from the ceiling. Using the guideline that 50-100 foot candles are required for the task of food preparation. The lower bound on foot candles for kids that can see, and the upper bound for old people that can’t see. I’m middle aged and can’t see well – went from "see fine" to "can’t see squat" in low light in about 4 years. I was considering 5" 75par30 on dimmers. Downside, I think, is heat output (will be fine in Great White North in winter, no so good in summer) and cheaper (initial costs and dimmers), versus low-voltage which is somehow better light and cheaper over a long time. Am I missing something here? Aside, I’ve discovered that my joists are 7". (I would have thought they would be 8" trimmed down to 7 ½, but no). The 5" Halo cans I’m considering are 7" high and would be flush with the subfloor above. Given that you’re supposed to be ½" from joists, I assume that flush with the subfloor would be a no-no? The low-profile 5" cans don’t come with the specular trims (which other posters think wonderful to cut glare), so maybe I get pushed to the MRs regardless. |
- Posted by normclc (normb@norburn.com) on Mon, Jun 8, 09 at 22:10
| Hi wildpack I'll try to answer two of your questions I specify the MR16 lamp for task or accent lighting because, |
| thanks for the response. So the housing is shallower because they've moved the bulb down. I've been surfing the net for recessed lighting info for so long that I'm missing the obvious! Need to digest the other info. thanks. |
- Posted by venice_2008 (My Page) on Wed, Jun 10, 09 at 11:14
| Wildpack, a good post, as I too feel like I am missing something basic, despite reading reams on paper on the topic. I'm in a similar situation, but am getting conflicting advice on what to do. In fact, it's this competing advice that's doing me in. I'm about to post on my dilemma ... if I get any responses, then there might be something in there to help you, too. |
- Posted by venice_2008 (My Page) on Fri, Jun 12, 09 at 8:43
| Wildpack, I strongly suggest that you go to a good quality lighting design store and get a consultation. I had done loads of Web and other research, and made some casual visits to a few stores, but until yesterday I had not done a "proper" consultation with a lighting designer. I am immensely glad that I did, and while I fully expect this to cost me more in the end, as I will buy from them and they're not cheap, it's worth every cent to me to have a properly and beautifully lit kitchen. And, I am breathing so much easier now. Let the experts help you. At a good shop, they'll be happy to do so. And, you'll get all the info you need to make your final decisions. |
Return to the Lighting Forum
