Mon, Jun 6, 11 at 10:38
| If you have a metal box that you are mounting this to, and it has a house ground in the box, wrap that house ground on the ground screw on the mounting kit for this lamp, and use that. This will ground the light. Mike |
| Stranded lamp wire will work as long as you can secure it with the appropriate screws. Grounding wire is typically solid wire but either will work. |
| "Grounding wire is typically solid wire but either will work." Solid wiure is rarely used in fixtures. The grounding wire for a pendent fixture is normally bare stranded wire. Two conductor cord is used for the hot and neutral (temperature rating determines the insulation required) and a #18 stranded bare wire is the ground. |
Return to the Lighting Forum
