eye ball trim
Posted by sevenecho (My Page) on
Sun, Jun 21, 09 at 9:08
I will be installing 5" recessed cans in the kitchen ceiling. The ceiling has a slight slope, 1" in 12", or about 4.75 degrees. Should I use regular trim, or consider eye ball trim so I can direct the light straight down? Any other considerations with regards to lamp options?
BTW, Lowes has the eyeball trims on sale for 10 bucks.
RE: eye ball trim
Yes, and I tryed to put a bulb in that fixture at Lowes and it stuck way out. No wonder it is on sale. I got the recessed 5" can from HD because it is approved for insulation, even though I have no installation around it. I added the halo baffle (think h99RT) (lowes price matched less 10% compared to HD which was a lot cheaper on the baffle). But HD is the only one with that 5" recessed can. And N:Vision 23 watt CFLs from HD. Hope they do not burn out quickly.
Good Luck,
Bob
RE: eye ball trim
Correction: baffle is the Halo 5001p.
Ask NormCLC what kind of small bulb you could use in that small fixture.
Bob
