| Hi -
We are remodeling our kitchen and currently working through the light design. I have included pictures below. A few things to note: - we are working with a sloped ceiling (8' on the right going to 12'9" on the left)
My primary questions are related to the layout of the recessed lights.
I have taken a pass at a layout below, but any suggestions/comment would be appreciated. Thanks, Jeff
| The formula I used was to estimate ~ 35 lumens /sq ft. Assuming ~ 600 lumens per recessed fixture. In your setup, the number of recessed fixtures could be less, depending on the light output by the chandeliers. Typically, lights should be placed close to the counter edge, except for the area around the chandeliers. There could be interesting shadow patterns. If you're planning on being able to control some lights separately (ie - chandeliers), they should be on a separate switch. With home automation, you could have separate switches and yet control things from a central console. That way, lighting groups could be controlled in unison or separately. HTH David |
| Hi David - Thanks for your suggestions. I've updated the plan as follows and removed 2 recessed light, although there might still be too many. I did put in a separate switch for the chandeliers and recessed over the islands. Any other suggestions would be appreciated. Thanks!
| Jeff, I assume that you're considering dimming? Vary the mix of recessed can types? You probably can remove the recessed can near the hood. Have you thought about under cabinet lighting? David |
| Hi David - - I was planning for dimming on the chandeliers, but likely will use CFLs for the recessed - they do have dimming capable CFLs, but I don't think their very good yet. - I haven't thought of varying the recessed can types - are you suggesting just different sizes? The only cans that i've seen for sloped ceilings are in 6" sizes. - I haven't chosen the undercabinet lighting system yet, but the green bars are supposed to designate under-cabinet lighting. I don't have a lot of upper cabinets though. Jeff |
| Hi Jeff, Would you be willing to consider LED lighting, specifically CREE CR6 lamps? They will be available this month for < $60 which will make them more cost effective than non-dimmable and dimmable CFL cans. The typical CFL can would cost ~ $60 w/o the lamp. The dimmable CFL cans could be more than $100. No, not just the can size, although that would be a good start. Hopefully you don't have to deal with Title 24 type laws where you live. David |
| The CREE CR6 looks promising and yes, I'd be very interested in this. However, I'm not sure on a sloped ceiling it would fit though. Since the trim is built-into the assembly, there doesn't seem to be an option for a different trim. Am I understanding how that works. Thanks for all your suggestions. |
| Jeff, Cree lights come with trim attached. The trims are removable and there are a number of choices available from CREE. Take a look at the CREE or the polar-ray website. The LE6 could be more suitable for sloped ceilings. |
Return to the Lighting Forum
