Kitchen Remodel - LED Uplighting & Under Cabinet Lighting
Posted by judi82 (My Page) on
Mon, May 31, 10 at 16:04
Now that I've settled on LR6 down-lights, I need to focus on dimmable up-lighting and dimmable under cabinet lighting.
I am interested in a LED swivel tube produced by Diode LED. The tube's mounting clips allow you to position the tube at the exact angle you need. A 20 inch tube has an energy usage of 3.6 watts and produces 185 lumens. I like the idea of being able to adjust the direction of the light source, but these swivel tubes only come in 3000 K and I have decided on 2700 K downlights. Will the difference in kleven made a noticeable difference? Should all light sources in the kitchen be the same kleven?
Are there other choices/types of LED up- and under-cab lighting that would make more sense?
RE: Kitchen Remodel - LED Uplighting & Under Cabinet Lighting
Yes, there will be a difference in that the light will be whiter.
I don't think all light sources need to be of the same color.
I used neutral white under cabinet lighting (environmentallights) and LR6 can lights.
DSCN0899
As for other choices of LED, you could take a look at www.environmentallights.com. They have warm white under cabinet lighting as well. Note that there are a number of other resellers who carry the exact same LED strips. - superbrightleds.com, phototonier.com, ...
HTH
Thanks, David. I'll check them out.
We cant help with the can lighting, but if you email me I can send you a pdf of the LED under cabinet we mfg.
•Maximum light length is 12 ft. long
•Custom lengths manufactured to the inch
•Day White LED/6,500K or Warm White/2,850K
•White housing extruded UV stabilized plastic
•1" LED spacing
•120° viewing angle
•Approximately 100,000hour lamp life
•Slim-line contour of continuous light
•White mounting chips included
•24 lumens per LED – 288 per foot
•2 watts per foot
