Wed, May 27, 09 at 14:05
| I received a quote to have two recessed lights installed in my condo for $1200.
This seems pretty high to me but I was wondering if there is anything I'm not considering that would make it so high? Thank you! |
| That does seem high. But what is the scope of the work? Does the electrician have easy access to where the lights are going to be installed and where the switch is going? Because if not, it can be costly to install. What is the material cost of the actual recessed lights. You probably want to get another quote or two to see what you get. |
Return to the Lighting Forum
