| I have no idea if track lighting is "out". I've been looking at it, myself, and have decided to use some in our new place. That said . . . I might put in track lighting, but aim the heads up at the ceiling, so the light is (mostly) indirect. Use some of them for direct task lighting, if you like. Or, for a more labor-intensive option (more drywall & electrical work), I would put sconces around the room, and use lamps for task lighting. Unless you're going to be having hamster shows or micro-stadium football (both of which need great lighting I've heard ;o), an overall good ambient light is great for living spaces. This isn't a kitchen, after all. Hope that helps . . . |
| It's not out, but it has been updated - the clunky plastic of yesterday is out. The new look is streamlined metal-finished tracks and lines with lots of variety of track lights and pendants. I have beamed ceilings like yours and am about to redo the old tracks. Do you have Lamps Plus? They will come out and give you a free consultation, or you can peruse their catalogs. Since your celing is not that high, nestle the tracks on the inside of a beam. There are also cable systems where you can run a cable between the beams and hang pendants off them, say over the coffee table. |
Return to the Lighting Forum
