| Hi, I'm going through a kitchen remodel and trying to figure out a lighting plan. Research on these forums,
elsewhere on the web, recommendations from kitchen planner, and electrician haven't led me to a final decision, so I'm looking for help. Generally I seem to be headed in a direction where recessed lighting is the main/general lighting for the room(which is
My proposed placement of these recessed lights is centered on the edge of the various sections of counter tops. The
For my other lighting layers, it is my intention to have LED under cabinet lighting everywhere. Trying to find a
Originally I was also going to have a ceiling fan+light in the center of the room, but I've reconsidered the necessity
I'm looking for whatever input I can get. I don't have much of a touch for lighting other than knowing when I'm in
Here's an overhead plan with my proposed recessed light locations in red:
Other views of the setup can be found HERE. |
| The CREE lights perform just like incandescents in terms of light color. |
| The center part needs some lighting - either a fixture (eg - chandelier) or more recessed cans. The CREE LR6 lights do outperform both incandescents and CFLs in cans - The cans are light traps. For under cabinet, look at environmentallights led light bars. HTH |
- Posted by stealthrug (My Page) on Wed, May 19, 10 at 10:02
| I failed to describe the switching control arrangement previously. I intend to have the three varieties of lighting(general, under, and over) controllable from either end of the room. This would be an all-or-none arrangement for each type, single switch activates all recessed/general lighting, single switch for all under cabinet, ... For the general/recessed lighting I intend to have that dimmable from one side of the room. This central fixture that you see as necessary, would that be a member of the general lighting class(always on with the recessed fixtures)? I didn't mention that the ceilings are 8', so uncertain on an actual chandelier, at least what my mental image of a chandelier is. Thanks. |
| You could use a surface mounted fixture, ~ 4 more recessed lights or ... I agree with you that a traditional chandelier (ie - like the ballroom chandelier in Beauty & the Beast) would be inappropriate. If you're considering dimmable CFLs, I'd recommend that you take a close look at the CREE CR6 & LR6 lights as an alternative as they are cheaper to procure and operate. |
Return to the Lighting Forum
