Mercury Vapor Yard Light
Posted by bellaterra (My Page) on
Mon, May 17, 10 at 10:15
I have a yard light that serves as the only exterior lighting for two doors coming from the house. I believe it is a mercury vapor light. I would like to replace it with something more energy efficient, but just as bright.
Would an LED light fixture provide this for me? I'm assuming I would need an entirely new fixture to replace the existing ballast.
Any help would be greatly appreciated.
RE: Mercury Vapor Yard Light
I don't know of anything available in LED that would be better.
I would recommend finding out exactly what you have. Is there an MV designation on your lamp? This will indicate mercury vapor. How many watts is the lamp?
I would then remove the ballast and run line voltage to the fixture. My choice would be a high wattage CFL. There is no LED that will adequately replace a mercury vapor lamp.
I would recommend a commercial grade CFL(not the residential spiral)with a minimum 2-42W TRT lamp or equivalent. Depending on how much lighting you actually need a high pressure sodium(HPS) fixture might suit your needs.
