Air Switch for Lights?
Posted by rmiriam (My Page) on
Thu, May 20, 10 at 9:24
I'm trying to put some accent lights in my new built-in bookcases, but the wiring and putting in a new light switch is proving a bit complicated. So I was thinking that I could put the lights in and plug them into an air switch, like one would put in for a garbage disposal, and the switch could be installed on one of the shelves. Does anyone have a reason NOT to do this? No one seems to use air switches for this purpose, but when I tested the garbage disposal one, it worked just fine.
RE: Air Switch for Lights?
With the Maestro wireless a switch/dimmer could be cut in and the Pico remote can be hand held or mounted in a wall plate. One would need to tell the provider what type of lighting is being controlled to place the order.
There are other options at a store like SmartHome.com
Seriously? An air switch in the bookcase?
Here is a link that might be useful: Maestro Wireless
Sure. There are less expensive ones available through Westek too.
