| I'm considering 24V LED light strips for under and over cabinet kitchen lighting and want to understand how to wire them.
The plan would be to have a total of 6 zones of light strips, 3 zones for under cabinet and 3 zones for over cabinet with a 100 Watt Class 2 DC driver installed in the sink cabinet to drive them. Am I right in assuming I would first T the output from the driver into 2 zones for uppers and lowers and then further T those 2 zones 3 more times for a total of 6 zones? If that is correct how do you split the wiring? Do you just use junction boxes and wire caps? Or, should I use a T-connector like the HADCO LCV4? They are a bit pricey but look convenient. I guess I should try to keep the wire distances and power requirements of each zone fairly equal? Or, am I totally wrong about how to do this? |
| Yes, you can use junction boxes and wire caps. Alternatively, you could use Ideal powerplug / In-sure connectors. http://www.idealindustries.com/products/wire_termination/luminaire_dis connects/ http://www.idealindustries.com/products/wire_termination/push-in/ How much power do the strips require in total? |
| Haven't decided exactly how many I want to use, but expect total to be between 50 and 65 watts. So, with those connectors do I push one set of wires into the input side and two sets on the output side? 16/2 AWG wire rated for in-wall OK? |
| You'll need to follow the manufacturer's instructions. LED systems can have very specific rules and guessing isn't a good idea. Class 2 power supply means you don't need J boxes. This is similar to door bell wiring with power limited transformer. |
| Yes, the Ideal connectors work that way and are a better choice than wire nuts. Take a look at the following site. It would help in determining the gauge of wire and max length possible. You have to calculate the power consumption each run takes. There is a voltage drop across the light bars. The max limit on the number of light bars that can be connected in series is typically stated by the manufacturer/ vendor. Each zone would probably have to be wired in parallel not in series. |
Return to the Lighting Forum
