Tue, Apr 21, 09 at 10:51
| Going out on a limb... Consider eliminating the arch and make it a retangular art niche so that you can display some more paintings on the wall and get some better lighting above with maybe four 4" low voltage recessed fixtures. If that is unacceptable the next thing is to put in three low voltage recessed fixtures. The center one aims at the painting, the ones on either side aim straight down. You will need something capable of about 40 degrees to correct for the angle. |
Return to the Lighting Forum
