Sun, Mar 7, 10 at 18:58
| We have 2 recessed lights in our vaulted ceiling in the living room and one in the kitchen. The house was built in 1985. We are planning to upgrade the insulation above the vaulted ceiling. We're concerned that if the job is not done right and the new insulation touches the light fixtures there could be a fire hazard.
Should we replace the recessed fixtures and, if so, what kind should be get? |
| Pull a can. If its "IC" (insulated ceiling) its designed to accommodate insulation butting up to the can. If not, then you have a fire hazard if you add insulation to the ceiling. |
| Non IC rated housing generally need 3" of space on all sides. If you are adding insulation, you can make barriers/box around the housing 3" away to hold back the insulation without changing the housing. |
Return to the Lighting Forum
