Mon, Mar 30, 09 at 14:39
| What should be used to seal gap around sheetrock to recessed lighting? used rotozip to cut around lights and want to seal it before blowing insulation back up in attic ? Used thomas lights which dont have a gasket or anything to seal it up. |
| If the gap is just the width of the rotozip cutter you should be able to caulk it. If larger you may need to use drywall compound. |
Return to the Lighting Forum
