Can I use the solid apollo for my undercabinet lights and on the inside of my upper glass cabinets? Seems like I could just have the electrician install plugs in the wall then I could install the leds when I get them delivered. It seems like they will be bright enough and that it uses almost any dimmer. What do you think?
Thanks, Peke
http://www.solidapollo.com/driverless-led-strips/
SKU SA-DLS-5050-W
Dimmable Yes by virtually any wall dimmer
Minimum cut 50cm
LED Color White
Color Temperature (kú) 6000K
Color Rendering Index (CRI) 82
Lumens per Foot 274 Lumens
LEDs per Foot 18/foot
Operating Voltage 110V AC
Watts per Foot 4.4W
LED Type Espistar 5050 Trichip
Beam Angle 120
Warranty 3 Years
Weight .75 Lbs
Size W:.47" X H:.28"
Mostly used in Linear Lighting
IP Rating IP67
Expected Life Span 50,000 hrs
Product Color White Circuit
Working Temperature -20-140F
Certificates CE, RoHS
or here is a warm white:
SKU SA-DLS-5050-WW
Minimum cut 50cm or 19.67"
LED Color Warm White
Color Temperature (kú) 3100K
Lumens per Foot 220 Lumens
Watts per Foot 4.4W
Beam Angle 120
Warranty 3 Years
Weight .75 Lbs
IP Rating IP67
David
PekeOriginal Author
Egypt Lake-Leto Lighting · Midland Furniture & Accessories · Wilmington Furniture & Accessories · Alpharetta Furniture & Accessories · Silver Spring Furniture & Accessories · Barstow Interior Designers & Decorators · East Patchogue Interior Designers & Decorators · Mansfield Interior Designers & Decorators · Grafton Electricians · Bowie Decks, Patios & Outdoor Enclosures · Livingston Decks, Patios & Outdoor Enclosures · Meridian Decks, Patios & Outdoor Enclosures · Minneapolis Decks, Patios & Outdoor Enclosures · Puyallup Decks, Patios & Outdoor Enclosures · South Lyon Decks, Patios & Outdoor EnclosuresDavid
PekeOriginal Author
David
PekeOriginal Author
SparklingWater
PekeOriginal Author
SparklingWater
