Soffit fixture replacement
Posted by jxbrown (My Page) on
Thu, Mar 13, 14 at 3:43
I have a room with soffits that are currently lighted with 8 individual 48" T12 fixtures. Since there are two bad ballasts, I would like to swap out the old fixtures for LED fixtures. I know that there are T12 retrofit kits, but since the existing fixtures can be easily removed, I don't need a fixture that is specifically designed for retrofit. Any suggestions? I have Cree retrofits in my can lights and am really happy with them.
RE: Soffit fixture replacement
Cree UR or ZR series if you're only interested in LED. Both the UR and ZR are in the same approximate price range (~$100)
http://www.cree.com/Lighting/Products/Indoor/Troffers/ZR-Series
If fluorescents are ok, you could consider using T8 fixtures - lower upfront cost than the UR series.
For T8 just buy something like these (GE 132-MVPS-N) on ebay and drop them right in if your luminaires are wired for rapid start and they are in good shape. It is really your best bang for the buck, and you can get good color choice and color rendering. You can find excellent ballasts on Ebay for less than $10 if you are patient and certainly less than $15.
If the sockets are for instant start, you have to change the sockets as well. It can be challenging to find the right, unshunted, sockets, for a decent price in my experience. If the luminaires are wired with more than one lamp/luminaire to a ballast, you need multi-lamp ballasts. You can switch to this configuration if you desire. It means running ballast cables or wires PROPERLY outside the luminaires which will take some rewiring, but cost less.
For more light, use MVPS-H and for less, use MVPS-L.
