Need help with discontinued lighting solution
Posted by bandjo97 (My Page) on
Wed, Feb 1, 12 at 18:15
Hi there,
Several years ago our contractor decided to try out these "new" and easy lights in our master bedroom and closet.
They came in an easy to install kit and the wiring daisy chains the 3 lights together and ultimately converge into a transformer which is then mounted on the wall and plugs into a power socket.
Now they don't work and I can't figure out why. The company is long gone. I was wondering if there was a comparable product out there or if anyone has any suggestions that wouldn't require a lot of work and the need to hire an electrician.
I'm not against hiring someone, but would rather try to replace/repair ourselves first.
here is a link to the lights.
http://www.smarthome.com/4600LF/Fixed-Recessed-Halogen-Light-Fixture/p .aspx
thanks so much if anyone has input, it would be great!
RE: Need help with discontinued lighting solution
The most likely cause is that the transformer failed. If you can get an equivalent, replacing the transformer is the easiest solution.
Thanks... I'll look into that.
