Track Lighting Question
Posted by andersog (My Page) on
Mon, Feb 28, 11 at 17:53
I have a track lighting system in which the strip is line voltage, and each light fixture has a transformer in it which converts to low voltage. Is it an issue in a single track to have different bulb types and wattages? I have 2 strips, each with 4 halogens, and aside from the 400 W of energy, it gets hot in my kitchen in the summer. I was thinking of switching some of the bulbs to LED's to lower the power useage and heat generated.
RE: Track Lighting Question
I don't see any harm in changing some or all of your lights to lower wattage incandescent bulbs, if they're available.
I've also seen a few low voltage LED retrofit lamps that look like they'd work with track lights.
Be careful, though - a lot (maybe the majority) of LED manufacturers' and vendors' claims for incandescent equivalence are completely bogus. I see vendors claiming a 1 watt LED is equivalent to a 20 watt incandescent, or that a 3 watt LED is equal to a 40 or 60 watt incandescent. This is WAY off the mark. Compare lumen output, not equivalence claims.
Many of the cheap LED retrofits also don't come close to their advertised average life.
Thanks. I have a few LED bulbs which use considerably less energy, however as you say they provide less actual light output. As a result I was planning on only switching half of the lights to LED's. I have 2 - 6 foot tracks, each with 4 lights, currently 50 W each = 200 W. If I replace just half of the lights I'd save almost 200 W and the heat output in my kitchen would be less (ie I would replace 2 on each track to balance the lighting).
