| Hi all,
I'm looking for some low-profile (less than 5" of drop height) ceiling line lighting (e.g., track lights) to illuminate closets on both sides of a short hallway . Any ideas? Thanks,
| The link is for miniature track lighting. You also might consider fluorescent under cabinet fixtures mounted on the wall above the closet doors. |
Here is a link that might be useful: Juno Trac 12 miniature track, remote transformer
| Thanks for the suggestions. I can't tell from the documentation how low the Junos are - Re: the fluorescent, I've considered running a tube down the Thanks again! Paul |
Here is a link that might be useful: indirect lighting with ceiling reflection
| Some of the fixtures get shorter when aimed down. Look at where the pivot point is. The track is 5/8". I was suggesting fluorescent in the closet. You need several inches of space between a fluorescent lamp and the ceiling to do indirect lighting or the lamp reflection off of the ceiling will be harsh and not diffuse. |
| The Juno Trac 12 lights look great - however, they are prohibitively expensive. A 4' run of 3 heads apparently will cost around $250. Re: fluorescent in the closet - that won't really work in this case... the configuration of the closets is such that Thanks, |
Return to the Lighting Forum
