Anyone heard of DMF lighting?
Posted by amandasplit (My Page) on
Wed, Jan 2, 13 at 17:17
Hi! Thanks to the help of davidtay we are finally starting to understand our lighting choices.
For our kitchen, we are trying to choose a 4" LED housing/trim combo.
Has anyone heard of DMF value line? This option would be about $100 and was recommended by our local lighting store. She suggested a 3000k option with 800 lumens.
The other two options are Halo H4 + housing or the CR4/GU24. (These would be about $60 and $70.)
How do we choose? Thanks in advance!
RE: Anyone heard of DMF lighting?
They have been around for some time. I'd venture to say that the cost is higher given the smaller production run and distribution network compared to Halo, Cree or Sylvania.
In addition, some counties may have subsidies on lamps such as the Cree CR series.
That's good to know. So quality wise, do you think there is a difference?
I don't think there is a significant difference, but I never seriously considered 4" led recessed lighting as cost effective solutions until the CR4 appeared.
Thanks so much! I'm pretty sold on the CR4, but need title24 compliant cans. We ended up buying the Halo cans at HD, do you think these CR4's would work in the Halo can? It doens't exactly say it's a GU24 connection anywhere.
http://www.polar-ray.com/Cree-CR4-575L-GU24_p_416.html
Which Halo can did you buy - the H99ICAT?
The GU24 is the connector. If you see a screw in connector, that is the E26 base. Unless you want to modify the can, you need to get the E26 base CR4.
There is some info on the kitchen recessed lighting link on title 24 compliant cans.
We got the h995ICAT with the orange connector thing (not Edison since that's not title 24 compliant). Is the orange connector a gu24 base? Or is it some halo proprietary connection?
Halo proprietary. The Cr4 gu24 should come with a GU24 pigtail which is meant to be spliced to the wiring.
Here is a link that might be useful: Cr4 install pdf
Cr4 pigtail
Snip off the halo connector and use the pigtail instead.
