Landscape LIghting Brands
Posted by crabapplemcn (My Page) on
Thu, Jan 29, 09 at 10:04
I wanted to do some low voltage path/flood lights outside my house and wanted some advice on good brands or online sources for good metal lights. I don't want really expensive ones but a step above Malibu/Big Box store kits. I am particularly looking for some well lights for around a patio also. Thanks
RE: Landscape LIghting Brands
In May 2003, I installed a system. At that time, I thoroughly researched online sites.
The one I used is at www.landscape-lighting.net
I bought their 300W transformer and their F7150 (x9) lights.
The only complaint I have is that the metal light screws into a plastic stick thingey that goes into the ground. The plastic, although decent for the style, is what gives if you "bump" into the light. I have some lights in my yard, next to boulders, and the kids/DH aren't as careful as I'd like around the lights. The glass cover has a really nice, tight fit.
Last fall, i bought 10K hour rated ushio bulbs and they have all failed, after 1500 hours. Very frustrating. For years I used the 5K hour ushio bulbs and they last at least 5K hours, over a year of full night illumination. Stupid of me to expect the 10K hour bulbs to last twice as long as the 5K!! Stick with the 5K hour bulbs - Superline from ushio IMO.
Volt makes some of the most economical professional grade low voltage landscape light fixtures (brass, copper, aluminum).
Re: Ushio bulbs--they are among the most respected, trusted brand that is used mainly by highend professionals. Very unusual. Not doubting you, however would like to point out lots of things can cause premature bulb burnout-- over volted fixtures or the 'cascading effect'.
Overvolted--even 1 volt more than 12 volts will cut the lifespan by about 30%.
Cascading Effect--With low voltage, when one bulb goes out the other fixtures on the same run will now have a higher voltage (due to less draw on the circuit) causing the rest to burn out quicker. If you let 2 or more bulbs on the same run burnout without replacing them quickly, the rest of the bulbs quickly burnout due to this 'cascading effect'.
Here is a link that might be useful: Examples of Volt fixtures
