Wed, Dec 5, 12 at 19:42
| I have an LG Tromm about 6 yrs old. I changed the drain pump a bit over a year ago, worked ok for a bit. Now though the pump is running but it won't drain the water unless I unscrew the the filter and "vent it" .. then it pumps the water. Any ideas?? Thanks |
- Posted by jdenyer232 (My Page) on Wed, Dec 5, 12 at 20:28
| Check the hose between the drum and the pump for obstructions. Also check the pump and drain hose to make sure they are clear. |
