Kenmore HT4 / HF code - no water
Posted by tkdurbin01 (My Page) on
Sat, Dec 24, 11 at 1:56
Have an HT4 - model 110.45087400
Repair guy states we need Water Valve Kit - NO WATER / I turn on and doesn't seem that water is filling in - will go through for about 10 minutes with liquid detergent but the fabric softener isn't draining into machine either/ turns off after 10 minutes with what it seems to be damp detergent clothes..
Any ideas ?
RE: Kenmore HT4 / HF code - no water
Post your question/problem on www.automaticwasher.org. I'm sure someone on that site will be able to assist you.
Hey Tk, i checked searspartsdirect.com and found the part you need. here is a link to it, its 54 dollars and some change!
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-elite- Parts/Washer-Parts/8181694/0026/110/Model-11045087400/0583/0153200?key SuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCom pId=K0503012&diagramPageId=00004&productTypeId=x&searchModelNumber=110 45087400&subCompDesc=Dispenser parts&brandDesc=KENMORE ELITE&modelDesc=WASHER&blt=11
I replaced the Blue water valve and still broken.
When it is time to rinse - cold water - the electric part attached/above the water valve makes noise like it is straining to open or let water in but no water flows - sound continues for a few minutes. Then FH code...
Problem is when it is time to RINSE -
ANY help out there ?
