ge washer model gtwn5450dww & ge washers in general!
Posted by blondelle (My Page) on
Mon, Nov 5, 12 at 18:23
The LGs and Samsung were highly rated but I have a limited depth I can use. We had a Bravo 700XW and it didn't clean well at all. We lost it in a flood and need to replace. The simiar Whirlpool ones weren't well reviewed. This has 5 stars on the GE site, which is a lot more than some of their more expensive models rated there.
I checked out Consumer Reports but a model they rave about now, came in at the bottom of the heap 2 years ago. It was the same model. The highly rated ones have bad reviews from customers.
Do the regular machines clean better than the HE ones? The HE ones don't use enough water and the detergent doesn't seem as effective as the ones with all the suds.
How are the repair ratings on the GE? Any feedback would be appreciated!
RE: ge washer model gtwn5450dww & ge washers in general!
Strange that it removed all the caps in my post title. How odd!
You know what GE stands for? Good Enough;-) GE is not what it used to be, quality has gone down, parts are expensive, and can take a while to get some parts. That being said and in all fairness it seems that most appliance manufacturers have gone the way of GE as well. What type of machine are you looking for? Frontloader or toploader? What models are you interested in, answer these and then people can help you navigate through all the choices out there. Hope this helps.
opps, now I see the model number in the post title, the machine you are looking at is an HE toploader that will work similar to the Bravos. If you want the old fashioned agitator machines then you can check out used appliances places, or see if your local appliance dealer has some older stock laying around. I know some of the Euro frontloader machines are smaller and may fit into smaller areas.
