| I recently purchased a Speed Queen Horizon Front Load washer/dryer pair. This washer model does not get very much mention on this forum. However, this did not deter me in any way.
After using it it for several loads, I highly recommend this model because:
I did not need a washer with more than 5 cycles. My hot water is plenty hot, so I did not need a washer to boost that either. I had to go to a distributor to buy and install it, so that may be a drawback, not going to a local store. Based on the first several loads of clothes, I highly recommend this model to anyone undecided on what their next washer/dryer will be. Wish me luck! |
| Thank you for the recommendation and good luck! |
| I agree. I have had my SQ FL set for coming up on 2 years. They perform every function I expect of them without all the fuzzy logic. All-in-All, they have impressed me more than any other machines I have used. MRB |
| Interested in this. Can you say water-level compared with your previous FL? What I mean is, do you have an actual sealed door and show water up the glass or does it just give you a puddle like all the other FL's? Have you measured actual wash temp on a "hot" load? Heat loss in HE/FL's has been a constant topic here. |
| Water level is 1-2" deep. I ran the first load without clothes, so I could see what was going on through the glass door. This washer uses 14.6 gallons of water per cycle. There is a video on U Tube of a Speed Queen owner who showed how to adjust the water level up to the bottom of the doorway. Now that, my friend was an impressive video. Almost like a mini Niagara Falls churning in that video. I saw this on the automatic washer.org forum. I believe there are Speed Queen Horizon Quantum models used in laundromats use that can more easily adjust water levels - than opening up the back of the washer. I will wait the 3/5 years until I am out of warranty, before I adjust my factory water levels. No, I have not recorded hot water temperatures yet. Hope this helps. |
