Samsung Washer - Water ALWAYS Hot?
Posted by sheenalee (My Page) on
Sun, Oct 30, 11 at 20:35
Hi - I'm, new here!
We just bought a new front-loading Samsung Washer and Dryer set, and I've found that no matter what heat setting I choose for the water, the clothes always come out hot.
We thought maybe the guy had forgotten to turn on the cold water valve, but we checked that to be sure, and everything seems fine. I also tried to wash the clothes on Warm/Warm to see if they were any cooler when they came out, and they weren't - they were still steaming hot.
I decided tonight to stop the washer after a few minutes and feel if the water was actually hot or maybe just got hot during the spin (lame I know, but I'm out of ideas!)
Anyone else experience this? I don't care so much for my whites but I don't want my darks and colors to fade.
Sheena
RE: Samsung Washer - Water ALWAYS Hot?
Very well could be that the hot and cold water hoses are connected to the machine in reverse.  Not unusual that a delivery/install crew gets them backward, some machines are opposite from the "usual" and they don't check the labeling on the hose ports.
Run a Quick cycle with the temp set to Cold/Cold, pause it when the final spin begins, check if the drum feels hot.
I actually put it on Hot/Cold and paused it after a couple minutes, and the wash water was cold. We're calling the guy back to come and fix it!
Thanks! :)
You can swap the hoses yourself in much less time than waiting for someone else. :-)
Listen to dadoes, please.
If you want to ball the people out with a phone call, by all means do that. They deserve it.
On the other hand, calling them in to switch hoses for you is on a par with calling an electrician to change a light bulb. Don't be silly about this.
If you are disabled in some way, please disregard.
