3 prong shock
buddy50 (
Fri, Oct 14, 11 at 16:11
| Went to test a new 3 prong plug to see if it fit right and a big shock came out. There is a little burnt mark on the receptacle and a spec on the plug only one one prong. did this happen because it was not attached and grounded to anything? Can it still be used?? New regular maytag coming wed. Guy at the store said this would fit so i tried it anyhow. The other plug is like 25 years old so the new 3 prong is the same but a spec bigger?. Yikes I'm sure many people do not know not to plug a dryer plug in if nothing attached at the other end? |
RE: 3 prong shock
| Call an electrician right away. Do not plug anything into that socket until you have it checked (and replaced). This is how people burn their houses down. |
RE: 3 prong shock
It is very bad to have a three prong outlet with no ground wire attached to the outlet in the wall. The reason you got the shock and the burnt spot was because something shorted out when you plugged it in. The advice from oregpsnow is absolutely correct. Do not attempt to use this outlet until a qualified electrician inspects it AND the cord of the appliance you plugged in. Who installed the outlet? |
RE: 3 prong shock
| think you are missing the issue. It was new new 3 prong plug NOT EVEN attached to the dryer. So what happened when I plugged it in or before I got that far there was a short. What happens at the other end there are 3 wires with metal ends that eventually would go to the dryer. They were touching each other so that most likely caused the short plus they were melted to gether after the incident. |
RE: 3 prong shock
| Of course the loose ends would cause a short if they were touching. Toss the cord, buy another, and DON'T TEST IT as you did the first one. |
RE: 3 prong shock
| Have no idea why you would do something so foolish. Your cord is toast and the outlet itself may be compromised. Inasmuch as you obviously have little knowledge or experience with this, please hire someone who knows what they're doing to inspect and/or repair the outlet and advise you how to proceed. 220v is not something for someone without knowledge or experience to mess with. |
RE: 3 prong shock
| Oh, I get it now. You plugged in a cord to see if it would fit and the end opposite of the plug had three wires connected to nothing. The wires at that end touched and caused the short? Next time you do something like this make sure the power to the outlet is turned off first. |
