| My husband and I recently got a used Maytag Washer model A608, and I'm wanting to make sure I'm using it correctly. The Maytag website does not have a manual for it (if anyone has one that would be delightful) I attached a photo of the center dial, my biggest thing is what point to turn it too, in order to most effectively utilize the machine's washing power for my loads of laundry.
For every load so far I've added detergent turned it to the '10' and left it to its own devices - and it turns left until the 'off' point. The clothes seem to be getting clean and all that so maybe I'm doing it right, but if anyone has any insightful information I would be most grateful. |
| I have an A608. Very simple to use this machine. Regular cycle runs a wash period, drain & spin with a 1 minute spray (occurs at the smaller bracket), refill, agitated rinse (at the larger bracket), drain & final spin (aka Damp Dry), and Off. Perm Press should run a wash period, partial drain, refill (always select a Cold rinse for Perm Press loads), agitate for a minute, drain & spin, refill agitated rinse, drain & final spin, Off. The number selections in both cycles is, of course, for wash time in minutes. The designated Delicates and Knits points don't do anything different in the respective Regular or Perm Press cycle other than a shorter wash time. You can, of course, set any wash time you wish for any load. Soak cycle fills, agitates briefly, soaks for a few mins, then drains/spins, and Off. For a longer soak time, simply monitor the cycle until it stops agitating and push the timer knob in to stop the machine for as long as you wish. When ready to continue, pull the knob to finish the soak cycle. Soak does not rinse, so reset the machine for a full cycle of either Regular or Perm Press as desired. The Regular Action (full speed) or Gentle Action (slow speed) button choice can be used with any of the three cycles. In case you aren't aware, there is (or should be) a manual clean lint filter in the agitator. Grasp the top part of the agitator and pull upwards to remove the cartridge. Clean and replace it. Many people, particularly those who obtain a "classic" Maytag as a 2nd-hand purchase or included with a home purchase, aren't aware of the filter and may never clean it ... which results in accumulation of gunk and residue on it that makes it non-functional due to clogging and can cause a musty/sour odor. The filter is passive in that it depends on water currents flowing through the agitator, and it doesn't do much on the lowest water level. The small cup that sits at top of the filter cartridge is a liquid fabric softener dispenser. Add a dose of softener when starting the machine and it'll dispense into the final rinse. DON'T stop the machine or open the lid during the first spin -- after wash, before the agitated rinse -- or the softener will dispense prematurely and could spot/stain the clothes. |
| that photo brings back memories! that's the washer I had for many years, until last year, when I opted to get a samsung FL W & D at a fantastic sale price. the sammy does such a much better job of cleaning than the maytag. I had no idea that the maytag, working correctly was such a dog at cleaning our clothes effectively. Now, even my dirtiest, greasy rags come out clean. If you have never had a FL, I suggest you look into it, if clean clothes is a priority for you. |
- Posted by whovian007 (My Page) on Tue, Oct 9, 12 at 12:07
| @dadoes Thank you so much for your reply - it helped immensely and I feel a lot more confident in using my washer - Thanks! |
