| I came home from work today and most of the light were on on my dryer. The lights that weren't staying on were flashing every few seconds. I unplugged it and left it sit over night and this morning there is no change when I plugged it back in...any suggestions?
Thanks! |
| One (or more) of the electronic boards (display, sensor, or motor control) is likely bad. Best to call for service. There's no way to access diagnostic mode if the panel is malfunctioning. |
| How would I access diagnostics if the dryer is working. It's working at the moment. I would like to see if any codes come up. Thanks! |
| With Power off, press/hold Auto Dry Down, then press Power at the same time. One beep and all lights are off. This is Level 0. There are 10 levels (0 through 9) of diagnostic info but most are used for engineering development or factory production and are not relevant to field service. Only Level 3 and Level 5 are relevant. Press Auto Dry Up/Down to change levels. The LED pattern changes for each level. Level 3 indicates the recorded Last Fault. Press Auto Dry Up three times. The fault code is indicated by which drying progress LEDs are lit. Left to right, values of 16, 8, 4, 2, 1. Add the numbers for the code. Level 5 checks the moisture sensor circuit. The LED pattern should change when a damp cloth (or fingers) is touched across the bars, then change again when removed. If not, then the sensor circuit is not working. If you get lost on which level you're in, press Auto Dry Down repeatedly until it beeps an error tone, that's Level 0. Code 1 = communications error between the sensor module and motor control module Code 2 = drum gap cannot be located Code 3 = drum stalled Code 4 = invalid option link read (motor control) Code 6 = door jammed Code 7 = excess motor current Code 8 = exhaust sensor over temperature Code 9 = exhaust sensor under temperature Code 10 = sensor module low voltage Code 11 = lid lock open circuit Code 12 = lid lock switching device failure Code 14 = sensor module fault Code 15 = sensor module fault Code 16 = airflow restriction (high-limit heater thermostat triggered) Code 20 = door actuator stalled Code 21 = door actuator excess voltage Code 22 = door actuator open circuit Code 23 = door actuator interrupted by low voltage Code 24 = door actuator movement took too long Code 28 = data retrieval error following loss of power Code 29 = brown-out data retrieval error Code 30 = lid unable to lock |
