Laundry Hampers
Posted by Postvt (My Page) on
Tue, Sep 11, 12 at 16:23
I planned my laundry room around nice double pullout hampers (2 sets) of these -- http://www.rev-a-shelf.com/p-47-hamper-bottom-mount-aluminum-with-wire -bins-for-closet.aspx Unfortunately I didn't realize these were CLOSET depth and not CABINET depth.
I'm left with a ton of wasted space -- but I planned cabinets to fit these not the other Rev-a-shelf choices and I cannot find a way to get the 4 bins I wanted in there with the purchased items.
I have 2 24 inch wide cabinets and I want each to have 2 bins (dark/white each divided cold/warm water bins). I have suggested side by side mounting of the 11 7/8 wide ones but they aren't thinking that will work well. Has anyone tried that (in one cabinet)? Or if I could just buy baskets that size they could make a drawer base they sit in. I'm having a hard time finding something to buy that would fit in a 12 inch wide cabinet depth opening other than the whole roll out system.
OR the cabinet guy can make me a big divided drawer which would use all my space nicely - down side is nothing is removable (in my old house I never removed my removable rev-a-shelf baskets it just went straight to the washer) although w 4 bins the distance to the washer from the farthest bins might make me want them removable. That is one concern there. The other is do I really need something ventilated? They can make some holes in the large drawer if I want -- but the ventilated baskets or canvas of the purchased systems end up in a closed cabinet anyway. Does it matter? Does anyone have a solid wood hamper?
The other option would to build some sort of frame to hang canvas bags I buy or have made from. I'm not sure what exactly I need to tell him to make for this. I can look at some of the hanging bag hampers you can buy for ideas -- but curious if anyone has done this.
I also have 2 sets of these lovely hampers for sale).
RE: Laundry Hampers
1. ventilation: good.
2. more ventilation: better
3. shortest time clothes sit in hamper (with max ventilation) : best.
RE: Laundry Hampers
Can you exchange the Rev-A-Shelf bins you have for another Rev-A-Shelf product? We did the double bins, but we opted for the trash bins as they were larger--1 bin holds an entire load of clothes. They come in full height and under cabinet height. Here's a pic of ours...
Hope this helps!
RE:Laundry Hampers
I just looked at your post again and noticed the measurements of the cabinets. With 2-24" cabinets to work with, you could move the divider, add an additional divider and have room for 3 of the pullouts like I have which would give you 6 bins. Or you could just go with 2-16" cabinets with double bins & have an additional cabinet for storage.
RE: Laundry Hampers
Cabinets are built and in so not much I can do. Had I realized my mistake I would have sized for something like you have, I think we can get 2 11 3/4 units in or make a drawer to hold something, Bummer as I totally planned around these pullouts it totally missed the depth on them!! A lot I could have done if I didn't already have the two 24 inch cabinets!!
RE: Laundry Hampers
If you are set on leaving the cabinet boxes as-is, what about a 24" single door full height pull like I have? I think you could get 2 cans placed side by side perpendicular to the door & 1 can placed in there parallel to the door.
Another option would be to put a single jumbo size hamper in each one with a 24" door.
Yet another, would be to do like you suggested and turn the can perpendicular to to the door--1 in each side of the cabinet should work. Maybe you could put a smaller can in too for delicates or things that need pretreating.
I measured, and my cans are 14-7/8" x 10-1/2". As far as structure, my DM has her trashcans set up the same as mine, but the cans fit in a "drawer" built into the bottom of the slide. A few months back, Lowe's had some metal hamper sliding "drawers" that would work to set a bin into on clearance. That may be worth checking out.
Hope this helps!
RE: Laundry Hampers
Here's a $40 fix for you from Rev-A-Shelf with 2 backets set side by side perpendicular to the door front...
http://www.rev-a-shelf.com/p-395-double-bottom-mount-wide-waste-contai ners.aspx?special=:Web:Closeouts:
