| Hi all,
I wear a lot of cotton T-shirts. When I take them out of the wash, I notice that most of them seem to develop these weird "oily" spots all over them, that were NOT there before I washed the clothes. This drives me crazy. I end up having to put stain stick on the spots and re-wash everything constantly. I have a Maytag Neptune MAH5500, which is about 5 years old. I've had no trouble with it and otherwise it seems to clean my clothing just fine. I've heard that fabric softener might be the cause, but I don't like fabric softener, so I don't use any ever. I always use a name-brand HE detergent, mostly liquids, but occasionally I will use Tide powder. The detergent doesn't seem to matter; the spots appear no matter what. I always use the measuring cap, but I usually just fill it to the top. Is it possible I'm using too much? I've tried adding borax, Clorox II, Oxy Clean etc. to the wash, but none of that helps either. Am I doing something wrong? |
- Posted by nerdyshopper (My Page) on Thu, Jul 9, 09 at 13:42
| I don't know anything about the Neptune washers, but many years ago my wife kept accusing me of wiping my greasy hands ( worked on our car a lot) on the towels. It turned out the grease was coming out of the top of the agitator on our GE top loader and getting on clothes. Replaced it with a Whirlpool and never looked back. |
- Posted by jdenyer232 (My Page) on Thu, Jul 9, 09 at 14:29
| There are only two things that I have seen cause this, one is fabric softner, you don't use it so we can rule that out, the other is cold wash temps, are you using at least warm? If you normally wash in warm water make sure that the water entering the machine is acutally warm by interupting the cycle and feeling the temp with your hand. Occasionally a hot water valve on a machine will either plug up or fail to open. Some machines can detect these water faults and alert you, but older machines may not know the difference. Oh and if you do only cold washes then oxi-clean is not going to really work, sodium percarbonate which is the active ingredient in oxi-clean is activated by warm or hot water. To much detergent could also be a cause, try cutting it in half and see if that helps. Hope this helps. |
- Posted by curiousshopper (My Page) on Thu, Jul 9, 09 at 15:27
| The owners of the smaller 3.1 FriGEMores always complained about greasy spots on clothing and the usual culprit on those machines was premature bearing failure. But if it's ONLY on cotton T-shirts that doesn't make sense. As far as the detergent amount, the Neptune was a medium capacity 3.3 machine so I would say a full cap is probably too much detergent. |
| Hi, Because I don't have a heater on this machine, I always run it with the hot water. I see steam coming out of the water input and it feels hot going in, so I'm pretty sure that's OK. I suppose it's possible that it's not hot enough, because I keep my home hot water at 120 degrees. I will try using less detergent, though. I went back to look at the cap and it does have a line about 2/3 of the way up, so maybe I am using too much. I'll see if that helps. The spots could possibly be happening on other clothing as well, but I haven't noticed it. On my T shirts, it's immediately noticeable. It looks like I spilled food all over myself :( Thanks! |
| Do you cook a lot? I do and I find I have to inspect all of my t-shirts and stain spray every little speck and spot before washing to make sure they don't turn into grease spots. I think teeny little splats morph into bigger splats throughout the laundering process. |
- Posted by happymomof2kids (My Page) on Sat, Jul 11, 09 at 10:31
| Well, you can rule out the detergent by washing some clothes by hand and see how they turn out. I guess it could be some type of grease or lube used in the machine for the parts, but you said you've had it for a while so it seems unlikely. Are they like actual round spots or smears? Are they the clear type that just destorts the regular color of the fabric or are they brown or black? The answers to those questions may help narrow down the cause. |
| I also get spots- they are sometimes the size of a 'quarter', and sometimes'long-ish'. I don't cook, and sometimes it is the very first time I wash a new item. I notice on the t-shirts the most because they are usually a solid color. I thought it was the grease in Downy, but you don't use fabric softner... Please let us know what you find out-PLEASE! |
| Are you sure the spots are developing during the wash? What about the dryer? Try drying the t-shirts some other way and see if the spots are there. |
| Hi again, The spots are clear and they are a bit difficult to see, until you shine a bright light on the shirt, then they pop right out. The best way to describe it is some sort of oily stain that has dried on the shirt. I had thought it might be a weird reaction to my sweat and the detergent, perhaps, but I'm not sure now. I've tried using less detergent, but that doesn't seem to be helping; I'm still seeing the stains. |
- Posted by cryptandrus (My Page) on Tue, Jul 28, 09 at 20:05
| OK, this is weird... I just found a few greasy spots on a three cotton t-shirts this weekend, too. One splotch was huge! The others were like 1/8" in diameter. I don't use fabric softener either... and I definitely don't overload on detergent. I used bi-o-kleen premium powder. I do usually hang everything out on a clothesline, but this load went into the dryer... I hope it's not leaking oil on stuff... I don't use the dryer much at all in the summer months. The good news is that a rewash with Dawn dish detergent as a prespotter on the spots took them right out. Keep us posted... I'd like to know what you figure out. |
| could it be purfume ? I know i spray myself everyday. |
| My kids and I used to get these all the time. I was washing dark colored t-shirts twice because after they dried the first time, I'd see the grease spots and have to pre-treat and rewash. I cook but my kids certainly don't so I don't know what causes this. I started ordering STPP from the Chemistry Store and adding that to all my laundry and it's taken care of the problem. Tracey |
| I am researching the same issue only with my Fisher & Paykel Eco Intuitive washer. Clear oil/grease spots that appear after a wash. Appear on air dried clothes so I know it's the washer vs. the dryer. I'm glad I'm not alone but would love an answer too! |
| I have the exact problem. I discovered it was the fabric softener and a certain brand of soap. When I changed detergent brands, or added color-safe bleach, they disappeared. |
- Posted by Stepo(usefulidiotsteve@hotmail.com) onSun, Apr 17, 11 at 17:10
| I also get these spots... My mom told me a LONG time ago to just wash my tees with Ivory bar soap every once and a while (in the tub with hot water) and it will take them right out. Its always worked. Also for tees to keep them bright and blacks very black you should wash them once a month in warm water with NO soap and half a cup of white vinegar! don't worry they wont smell bad after. |
