Samsung washer leaking
Posted by allanj (My Page) on
Tue, Jun 12, 12 at 11:38
I have a Samsung front loading washer. VRT steam. It is approximately three years old. We washed a quilt in it and since that time the machine is leaking water after the cycle is completely finished. The water is at the front of the machine on the floor on the left side. We used woolite to wash the quilt. I cleaned out the detegent dispenser and the filter at the bottom of the machine. still is leaking. What could be my problem. Doesn't do it on every load washed.
RE: Samsung washer leaking
Do you have that little door in the front? If so have you done the maintenance? Check your manual for instructions. Also look at the little holes at the bottom of the rubber ring around the door. Look for lint or string plugging the holes. Sorry that's all I've got for suggestions.
