Constuction dos and donts for 2nd floor laundry
Posted by galleyette (My Page) on
Sun, Jun 26, 11 at 9:45
We are constructing a small addition that will include a second floor laundry room off the existing master bathroom. The interior dimensions will be approximately 5'W X 10'L. The current plan is to run sink, FL washer, dryer and folding counter, all along the 10' exterior wall. The new machines are LG and are built to reduce vibration. A floor drain will factor into the plan as well.
We have read several theories on floor construction for second floor laundry rooms, ranging from pouring concrete pads (with and without rebar), reinforcing floor joists, adding anti-vibration pads, and last but not least, using foam pool noodles wedged between the machines. Because this is a new build, we'd like to do it once, and to it right.
Is there a definitive 'best way' to do this?
RE: Constuction dos and donts for 2nd floor laundry
Your best bet would be to retain a structural engineer to review and design what you wish to accomplish. Second guessing might lead to problems. For example, the suggested concrete and reinforced concrete would create a mass that, if not anchored and designed properly, could lead to that mass swaying improperly under load, causing structural damage. (Seismic engineers know this all too well.)
Construction means, methods, and materials can all have complicated interactions depending are how, where and when they are used. Plus, you have building code regulations to address. Answer: There is no easy or definitive answer owed to the presently known and unknown values you wish to design around.
We used an engineer when the addition was planned to correctly assess the foundation requirements with the 2nd floor laundry in mind- I know we exceed minimum code requirements by a long shot. I guess the actual construction of the second floor laundry room, he left up to the contractor.
I have the impression that many people retro-fit existing second floor areas, particularly closets, to make room for laundry rooms. What do they do in the absence of an engineering report?
Surprised your engineer didn't do the 2nd floor too. However, you can use engineered-wood joist, or add sister joists (effectively doubling-up a floor joist). Since you are using a FL washer your movement will be side-to-side and you should take into consideration a worst case scenario (washer goes into spin and is completely unbalanced due to a washer fault). Try to design the flooring to drain without having have a curb, if possible. This is just for reference as it utilizes a pan: Avoiding a Laundry Room Flood in an Upstairs Laundry Room
Have you considered steel beams under the laundry room floor, and have them run under the machines and parallel to the wall to which the machines will back up. If the steel beams are too pricey, perhaps a good load-bearing wall under the area where the machines will sit? You really want to avoid the "trampoline effect."
Extra layer of 6/8" plywood (not particleboard) sub-floor perpendicular to grain of first layer might help, too. I suggest avoiding particleboard in case of a flood (not to mention the formaldehyde outgassing potential) .... p'board will swell and possibly crumble, too, if gotten wet from a washing machine hose blowing, or any sort of disaster. A really good grade of plywood, like ADX, should not. It's expensive, but you're looking at a small area.
Drain in floor is a good idea, too.
