Asko w6884eco washer problems
Posted by conate (My Page) on
Thu, Apr 5, 12 at 22:08
My wife and I bought one of these machines end of December and installed it early January.
We have had a huge number of bizarre problems: cycles stopping in the middle, the machine pumping continuously when o water present, and other things.
The circuit board has been replaced once and it is going to get replaced again.
Has anyone else had these problems with this machine?
Thanks ! Nathan
RE: Asko w6884eco washer problems
Do you have a copy of your service manual? If not, get one. Is your repair person knowledgeable about Askos or has replacing the board been used as a fix? Has the drain pump been removed and checked? I'm wondering if the washer is draining enough to drain the tub but not the pump.
Thank! We've just had a third board put in, so that's obviously not fixing it. The drain pump seems likely.
The other bizarre things...like a cycle just stopping...not sure about that one.
