| New GE GTMP400EMWS dryer.
I bought a new GE 7 cu ft electric dryer to replace an 16 year old Kenmore dryer (with top lint filter) because the old dryer occasionally causes brownish marks on the collar tips of shirts. Apparently the tips of the shirts were caught in the gap between the rotating drum and the stationary back plate. The gap of the old dryer will get wider due to the wearing-out of the felts/supports at the rear and at the front of the drum. So I decided to replace the old dryer. The construction of the rear end of the GE drum is completely different from that of the old Kenmore. There will be no gap at the rear to catch the tips of the shirts. The new GE 7 cu ft dryer seems to hold a bit more clothing than (say about 5% to 10% more than) the old Kenmore. It takes about 48 min to dry a load of cotton clothing using the normal cotton sensor cycle. I think that the design of the drum of GE is better but the overall construction of the Kenmore/Whirlpool is better. |
| My GE dryer is made in Canada with Model No GTMP400EMWS I think that the equivalent model in USA is GTDP400EMWS. |
| After using the new dryer for several days, my wife is quite happy with the new dryer because the clothing dried from the new dryer are softer than from the old dryer. |
| There are two heating elements in this GE dryer. It seems that the dryer will cycle only one heating element ON/OFF to maintain a desirable drying temperature while the other heating element is always ON during the drying cycle. In such manner, the drying temperature variation will be less than that of the other dryer using one heating element. |
| I bought a digital thermometer to measure the outlet temperature of the GE dryer. The sensor was placed in the lint tray. The setting was in normal cotton cycle with a typical cotton/mixed load. A) From 0 to 10 min, the temp was increasing slowly from 68F to 113F (47F increase) B) From 10 to 20 min, the temp was increasing very slowly from 113F to 118F (only 5F increase). C) From 20 to 32 min, the temp was increasing slowly from 118F to 149F (31F increase). D) From 32 min to 50 min, the outlet thermostat took over to the set-temperature of the outlet. The outlet temp as measured varied from 136F to 154F. When the temp exceeded 154F, both heating elements were cut OUT (OFF). When the temp fell below 136F, both heating elements were cut IN (ON). E)From 50 min to 56 min (cooling down period) the outlet temp fell slowly to 104F and at 56 min the buzzer sounded to end the drying cycle. |
| Regarding inlet and outlet thermostats ... are you referring to inlet as being a thermostat on the heating element housing, and outlet as being a thermostat on the exhaust air duct? If so, the INLET thermostat is likely an overheat safety thermostat and should not be cutting the element out during normal operation. It only comes into play if there's insufficient airflow across the element. Could be what happened during your test is that at start of the cycle (from 0 to 32 mins), the overheat safety thermostat was cutting the element out rather than letting it run continuously as it should to reach the target outlet temp (~155F). When the clothes are cold/wet, evaporating moisture holds the exhaust air temp down and the heat has to run longer to reach the target temperature. After 32 mins the clothes were sufficiently moving toward dryness and holding heat, the exhaust air temperature reached the target temperature and the element cycled off via the exhaust outlet thermostat (which is the only thermostat that should control the element during normal operation). The element then ran for shorter periods to maintain the ~155 air temp and didn't overheat the safety thermostat. |
| For GE electric dryer, there are a)one Safety Thermostat at the inlet which will cut off "both" heating elements when overheat b)one Control Inlet Thermostat at the inlet which will switch ON/OFF "only one" heating element to maintain the inlet set-temperature and c)one Drum Outlet Thermostat at the outlet which will switch ON/OFF "both" heating elements to maintain the outlet set-temperature. There are two heating elements (say about 2700 watts each at 240V) in the GE dryer. |
| Nice! Perhaps that's a redesign on the system to help protect fabrics from exposure to the blast of heat that [otherwise] comes through the grill at back of the drum. |
| For this GE model. a) The set-temperature of the Control Inlet Thermostat could be lower when its 9 Kohm is connected to the 120V. b) The set-temperature of the Drum Outlet Thermostat could be also lower when its 9 Kohm is connected to the 120V. A) When the Temperature Selector is NORMAL, both Control Inlet and Drum Outlet are HIGH. |
| I was advised to check the exhaust system of the dryer. The weaker part is the old exhaust hood which has 2.5" opening. This 2.5" hood is not recommended by the manual of GE dryer. I bought an new hood which has 4" opening. The new 4" hood was installed to replace the old hood yesterday. There is less restriction of air-flow using the new hood. I will try to find out if there is any improvement in drying time. |
| Today a similar cotton/mixed load was used to test the dryer with the new hood. A) From 0 to 10 min, the temp was increasing slowly from 66F to 117F (51F increase) B) From 10 to 20 min, the temp was increasing very slowly from 117F to 122 (only 5F increase). C) From 20 to 30 min, the temp was increasing slowly from 122F to 151F (29F increase). D) From 30 min to 45 min, the outlet thermostat took over to the set-temperature of the outlet. The outlet temp as measured varied from 133F to 154F. When the temp exceeded 154F, both heating elements were switched OFF. When the temp fell below 133F, both heating elements were switched ON. E)From 45 min to 51 min (cooling down period) the outlet temp fell slowly to 102F and at 51 min the buzzer sounded to end the drying cycle Note: |
| Most 29" WP uses "High-limit Thermostat of 250 deg F and Thermal Fuse of 360 deg F" at the inlet. The high-limit may not have a chance to cut-off the heating power because the inlet air temperature does not reach 250 deg during the heating up . The "Thermal Fuse of 360 deg" is for extra safety cut-off and non-settable. The GE uses two thermostats at the inlet - Safety Thermostat and Control Inlet Thermostat. I think that there are also two inlet set-temperatures in some new 29" WP dryer model with Normal/PP/Delicate(Gentle Breeze model?). |
| Looking at the data from the GE circuit diagram: a) The inlet temperature of the GE is maintained from 180F to 210F by the Control Inlet Thermostat and the Safety Left Thermostat Thus it seems that the GE dryer is working at a lower inlet temperature than the 29" WP dryer. This could be the reason why the WP does not cycle the heater until the target temperature at the drum outlet is reached. |
| Further findings for the GE dryer: a) NORMAL Temperature: b) PPress Temperature: c) Delicate Temperature: I will use the PPress Temperature most of time because the clothing seems to be softer with a lower inlet temperature . |
| I used the PPress Temp to dry a load of cotton/mixed this morning. It took about 3 to 5% longer to reach the target temperature at the drum outlet. It seems that the dryness and condition of the clothing is quite similar to that using the NORMAL Temp. I think that there is practically no difference in energy usage. Perhaps it is better for the clothing (especially for Cotton/PP mixed load) using lower inlet heating temperature. |
