| Hello,
The bearings are bad on my LG washer WM0532HW and I need to replace either the bearings or the whole assembly. It's very loud and leaking water. Does anyone know how much this will cost? It's out of warranty but I paid for a technician to check it and he says it's going to be about $600 and up for the bearing assembly and that's just parts. I hope he's way off because I can't afford a new washer right now. Thanks. |
| Many machines nowadays are engineered such that the manufacturer's procedure for bearing repair involves replacing the entire outer tub (or perhaps in some cases of frontloaders, the back half of it). The only reason I can figure is forced obsolescence by way of high repair cost. Rather than designing the machines so that bearings can be easily replaced and thus carrying the (smaller) parts related to bearings and seals as stock-items, they do it this way with the (bulky) tub priced so high as to discourage it from being done. |
- Posted by regus_patoff (My Page) on Thu, Apr 23, 09 at 9:55
| He may have given you that price for an assembly and/or he just didn't want to do the job at all ... |
- Posted by regus_patoff (My Page) on Thu, Apr 23, 09 at 9:59
| ... was he an authorized LG repairman ? |
| Well looking at the exploded view diagram in the manual that Regus posted above it certainly appears that the bearings are not part of the drum assembly (it looks like K121 is the bearings and K122 and K125 are the inner and outer seals). I just went through this with our Maytag Neptune and in the case of the Neptune the bearing is pressed into the drum, so bearing replacement requires replacing the whole drum and it is nearly a grand to have someone do that. But it doesn't look like it's the same way with the LG. |
- Posted by climbing_mt_washmore (My Page) on Thu, Apr 23, 09 at 22:03
| Thanks for the replies. I think we've gotten to the bottom of it. Hubby was able to get inside of the washer and remove the bad bearings. They had sludge looking mud inside but basically it was metal against metal. We're going to order just the bearings and hopefully that will do the trick. Regus - I think your 100% correct that the repairman didn't want to do the repair. He was difficult to nail down on an estimate and then he gave me that over the phone ($700 including labor). He wasn't an authorized LG repairman. Hubby thinks he makes his money just doing house calls but never actually repairs anything ;-) |
| Hi.. I've got a WM2432HW that is somewhere between 5-6 years old now and it's started getting very loud during the spin cycles to the point where you do not want to be around it or within 50 feet of it. It still works OK but I'm thinking that the bearings are shot. We've not yet called LG to see if they'd fix it under warranty and might do that this week. We've never had any issues before with it -- it's been working fine until now. Did your bearing replacement solve the problem? Any ideas on what caused the failure? |
| Ok.. I spoke w/ LG this morning and they indicated that only the motor and tub are under warranty and that I could have a local service organization take a look at it.. I called them up and spoke with someone knowledgeable and after describing the symptoms he thought it could be one of a few issues (hall sensor, tub assembly or bearings). He said that if I wanted to remove the rear panel (assuming I'm comfortable doing that) and see if any rust or goo is on the bottom of the machine. If so, he said that's an indication of a bearing/seal failure and it will cost about $600 for the repair... So.. Tonight I'll be checking that.. My hunch is that it's exactly that, since I had seen some indications of a little leakage in the past on the bottom of the pan when the machine was moved for a home remodel... I guess I'll start looking at a replacement as I'm not going to pony up $600 for this repair.. A few lessons to pass along after reading up on this sort of issue here and elsewhere : 1) Only use 2-3 TBSP of detergent -- only the HE variety (high efficiency). In our case we were frequently doing both which probably contributed to the overall failure. I'm going to assume these are universal truths relevant to any front loader. |
- Posted by Rob(rob.bellomy@gmail.com) onFri, Nov 12, 10 at 14:49
| Hi. If anyone whose replaced the bearings could give a guy some advice on the best way to access the bearings, I would be greatly appreciative. I went ahead with ordering the bearings and a new damper from the Sears.com link above (thank you, by the way!) because my rotor at the back of the machine resembled the original poster's - brown material that looked like mud and dirt but smelled metallic - but I'm not sure of the best/ easiest way to access the bearings. I'm hopeful I can just remove the motor from the back, but any advice is definitely welcomed. I have checked with appliance repair centers in the past (for another issue) and was told that they either did not do work on LG machines or quoted more than the cost of a new, top loading direct drive washer. It's a good machine overall; never destroyed any of my wife's unmentionables or my shirts (unlike our old Kenmore Direct Drive machine). Thanks, |
- Posted by Rob(rob.bellomy@gmail.com) onFri, Nov 12, 10 at 15:59
- Posted by Jacqueline(millerj@erinet.com) onTue, Feb 1, 11 at 12:43
| I have an LG WM2432HW bought in 5/07, used only 1-2 times a week (total maybe 150-200 times), not overlaoded, have always used Tide HE detergent in small qualtities...and the bearings are bad!! ARGH!..PS sits next to my 25 year-old Maytag dryer that's had maybe $75 worth of repairs over its lifetime Since repair costs seem to be prohibitive, I'm wondering how long I can run it without replacing the bearings? Can I still use it if I can tolerate the noise?...will this cause additional damage? ... any rough estimate how long it might last using 1-2 times per week?? Advise appreciated..Thanks! PS..based my choice to buy the LG from Consumer Reports ratings...first time I've been burned |
| Got the machine taken apart. Definitely a two-person job. Definitely do it where you don't mind getting a little water (smelly water, at that) onto things. I took mine apart in the garage. I waited too long to replace the bearings. The first bearing came out with the inner and outer races shorn apart and the ball bearings were not round; the shields were disintegrated. Hence the brown mud-like material that smelled metallic. Yuck. Second bearing housed in the outer tub assembly would not come out. I probably let the issue go for too long with bearings going out. My wife and I noticed the machine becoming progressively louder for probably 6 months before realizing this was an issue we needed to deal with. The damage to the bearings led to damage (scoring) of the arm that runs from the inner tub assembly and is the main horizontal axis on which the wash drum spins. Whether the bearings failed first leading to the scoring or the scoring was present early on (leading to water penetration into the bearing housing), I do not know. I realized at this point that I'd probably need to replace the tub assembly (if parts were available) and I was approaching replacement cost for a good, on-sale (it was Black Friday sales weekend when I tackled this task) top-loading energy efficient washer. My wife and I decided to scrap the old machine (got $12 at the recycling center... almost paid for my lunch that day!). We bought a GE high-efficiency top-load washer - GTWN4950LWS - and we love it. And it cost (with tax and extended warranty) what I would have paid in repairs, assuming I had purchased a new tub assembly. LG was an expensive lesson-learned. Still have the dryer (for who knows how long???) and an LG Refrigerator where the water-dispensing switch is broken and kind of rigged together (it started sticking 2 years ago and would run water and not stop until I pulled off the plastic cover and exposed the switch). No more LG for me. |
| I too have sworn off LG. They just aren't built to last. MRB |
- Posted by Joltyou(JdnRuss@hotmail.com) onWed, Apr 27, 11 at 5:08
| Well everyone thank you for all the information on the LG Front-load washer WM0532HW. I have a 2003 model purchased from best-buy when they first came out and have loved the machine. Since last year the machine has gotten louder, louder and sounds like a tornado is coming (mention of the freight train sound). Well I said screw it, by the time someone comes to check it out, drives out to look at the issue etc I might as well just purchase a new one. The problem is that the machine looks bran new and I am torn to have them take it away. I seem to have the same problems as you above have described. I looked at the cost of parts and decided it would cost around $300 as you confirmed I think you are right in the $600 range. Well I have enjoyed the LG washer and dryer I am tired of loading and unloading the washer on my knees, I have purchased the new LG Top-load WT5001CW and hope it will be as enjoyable. Thank you for all you comments and settling my thoughts about trying to fix and part with this one!!! |
- Posted by Frank(frankmay10@hotmail.com) onSun, May 22, 11 at 14:05
| Ours developed the same symptoms as JdnRuss WM0532HW over the past years. It got to the point that I told my wife that it will bring down our house (it sits on the laundry room second floor) by weakened the floor joints. Yesterday, it just refused to spin, and came up with LE and UE errors. So, reading these postings, I am grateful what my options are. Having owned the unit since July 2004, I thought it has served us well. So, I went and got a replacement WM2350HWC at Home Depot (thought about going with WM3360HWC) but decided we don't need the Steaming feature. If we have any of those heavily soiled clothings, we would take them to the laundromat instead. Thanks again for a very informative postings and sharing of information. |
| For anyone interested there is, in my opinion, a very good write up, with pictures, of one person's attempt to repair an LG front loader at he website below. I think he was wasting his time trying to isolated the spider from the stainless steel drum. |
Here is a link that might be useful: Attempted LG Washer repair
| That was an interesting post. Too much hate towards LG and armchair QB'ing for me though. It was really over the top, IMHO. That being said we did own that model, just in black. Lasted from 2004-2011 when a flood of sewer water (3.5 ft) made us get rid of it since we would never feel we were wearing clean clothes. It still ran fine for a couple loads after being flooded about 1/2 way up the door. |
- Posted by dlw(walshzoo7@peoplepc.com) onTue, Jun 14, 11 at 1:52
| Thanks for all the great advice. As I listen to the freight train chugging down the tracks (the washer) in the room next to our bedroom I worry could it blow apart? I have had to have the seal,the pump, and the bellows,(I have had the bellows replaced 4 times and have a box of new ones we ordered when my husband discovered that legos and anything else left in our sons' pockets would rip through the flimsy part and cause major water leakage. When the 3 rd repair man was called he laughed when I said it was only 2 years old and he said "I don't do LG" but when he knew we had the extended Best Buy warranty he changed his tune and started replacing everything. I have had an additional few years BUT this stinks. I like where the soap is added and where the controls are but I too am ready to give up. I wish I could post the sound, I know some of you have heard it. I think the bellows and bearings are a weak link. Unlike the Toyota truck we had that was recalled, and handled very well, 1/2 our purchase price back and they treated us well. Repair men weren't'evenavailable when we had a problem after 2 months with the washer. They hadn't anticipated problems so early they said. We are outside Wash DC, not exactly off the grid. LG is NOT standing by their mistakes. |
| Is there any video showing how to replace bearings on front load LG washers? |
- Posted by SmoothPower (My Page) on Tue, Sep 4, 12 at 13:51
| We have an LG front loader that started acting a bit out of balance during the high-speed spins. Taking some of the clothes out seemed to help for a while. But, after a few weeks, the drum vibrations were so bad that the drum was rubbing against the boot and making it smoke. We called LG and they had a local technician come out to see what might be the problem. I asked him to check the bearings. The tech said the bearings were okay but said that either an 'uneven load' or possibly something like a bobby pin or button had been caught between drum and boot causing it to smoke. We continued using the washer trying to balance it but the problem got worse and worse. We called the technician back and he told us it was the bearings that had gone. He quoted roughly $750. We paid less for the washer brand new! I decided to fix the thing myself. I decided to order: 1 inner bearing 1 outer bearing 1 inner bearing seal 1 spider assembly (this comes with the shaft attached) 1 seal for the two halves of the outer tub 1 mystery seal the technician said I needed... The technician tried to tell me that I needed to buy both halves of the outer drum and I needed a new steel inner drum and a new boot. I chose to not buy any of those. It turns out that I truly didn't need to replace any of these anyway, so I made a good decision. I followed the link above which details how to disassemble the washing machine. That worked really well. The part I had problems with was how to remove bearings on an LG front loader. This video helped: http://youtu.be/XaFF2-Rl8Nc Basically, I tried bashing them out with a rubber mallet and a screwdriver. That was going nowhere, and I was afraid I'd damage the casing that the bearing sits in, so I swapped the screwdriver out for a 6" extension from my 3/8" socket set. The rounded end was much more friendly to surrounding surfaces. I couldn't get enough umph from a rubber mallet, so I used an 8lb sledge and gently pounded the inner bearing out. That worked just fine. I turned the drum over, supported it on a couple car ramps to get the bearing up off the ground, and tried the same technique going the other direction. When that didn't seem to be working, I located a large steel bolt with a head just smaller than the diameter of the casing. I wrapped the head in a piece of shop wipe to keep it from scratching the casing. I put the flat head against the bearing and from inside the tub, hit the shaft of the bolt with my sledge until the bearing popped out. The reason this machine failed is because the aluminum spider deteriorated extensively. So extreme was the deterioration that all 3 spokes of the spider were cracked completely through except for a 1 inch section of one of the spokes. This is the same as if a car's mag wheel is cracked around ALL of the spokes except for 1" of one. So we narrowly averted catastrophic failure if the drum had broken free at 1000rpm. I'm ready to begin reassembly now. I'll post again to let you know how it went. (Parts were $150 by the way.) |
- Posted by SmoothPower (My Page) on Tue, Sep 4, 12 at 13:55
| We have an LG front loader that started acting a bit out of balance during the high-speed spins. Taking some of the clothes out seemed to help for a while. But, after a few weeks, the drum vibrations were so bad that the drum was rubbing against the boot and making it smoke. We called LG and they had a local technician come out to see what might be the problem. I asked him to check the bearings. The tech said the bearings were okay but said that either an 'uneven load' or possibly something like a bobby pin or button had been caught between drum and boot causing it to smoke. We continued using the washer trying to balance it but the problem got worse and worse. We called the technician back and he told us it was the bearings that had gone. He quoted roughly $750. We paid less for the washer brand new! I decided to fix the thing myself. I decided to order: 1 inner bearing 1 outer bearing 1 inner bearing seal 1 spider assembly (this comes with the shaft attached) 1 seal for the two halves of the outer tub 1 mystery seal the technician said I needed... The technician tried to tell me that I needed to buy both halves of the outer drum and I needed a new steel inner drum and a new boot. I chose to not buy any of those. It turns out that I truly didn't need to replace any of these anyway, so I made a good decision. I followed the link above which details how to disassemble the washing machine. That worked really well. The part I had problems with was how to remove bearings on an LG front loader. This video helped: Repairing Front Loader Bearings Basically, I tried bashing them out with a rubber mallet and a screwdriver. That was going nowhere, and I was afraid I'd damage the casing that the bearing sits in, so I swapped the screwdriver out for a 6" extension from my 3/8" socket set. The rounded end was much more friendly to surrounding surfaces. I couldn't get enough umph from a rubber mallet, so I used an 8lb sledge and gently pounded the inner bearing out. That worked just fine. I turned the drum over, supported it on a couple car ramps to get the bearing up off the ground, and tried the same technique going the other direction. When that didn't seem to be working, I located a large steel bolt with a head just smaller than the diameter of the casing. I wrapped the head in a piece of shop wipe to keep it from scratching the casing. I put the flat head against the bearing and from inside the tub, hit the shaft of the bolt with my sledge until the bearing popped out. The reason this machine failed is because the aluminum spider deteriorated extensively. So extreme was the deterioration that all 3 spokes of the spider were cracked completely through except for a 1 inch section of one of the spokes. This is the same as if a car's mag wheel is cracked around ALL of the spokes except for 1" of one. So we narrowly averted catastrophic failure if the drum had broken free at 1000rpm. I'm ready to begin reassembly now. I'll post again to let you know how it went. (Parts were $150 by the way.) |
- Posted by SparklingWater (My Page) on Tue, Sep 4, 12 at 16:29
| Oh my goodness SmoothPower. You truly did hard work. Ever since the bearings on my old 2000 Neptune stackable washer went out, I've been interested in knowing how bearings function, how to minimize damage/deterioration etc as a consumer (lighter loads, not too much soap all sounds a tad crazy). I came across the link showing corrosion of a <5 year old LG aluminum spider and if this is what happened on yours and its, no way will the owner be able to prevent a design problem. Look at the close ups and the authors point that there was nothing between the spider and the LG SS cylinder (Post# 475579). Just wanted to share this with you. I bought a SQ this spring. Hope its spider/cylinder design is better. Good luck on your reassemble. |
Here is a link that might be useful: LG washer spider
