Thu, Mar 8, 12 at 15:03
| If you have a Samsung 520, would you be kind enough to tell me what cycles you use for jeans, towels and knit polos? I have had this machine for about a year and I don't hate it but I'm not in love with it either! I've even had a bit of tangling and I know that's not right in a FL. So I must not be using the cycles correctly. Any help would be greatly appreciated. |
| I have a 520 and usually use the Normal Cycle without problems, including polos. not sure why you are having so much trouble with tangling. I find the washer does an awesome job and FAR, FAR better than the TL (older Maytag--when they were made well). The TL was constantly wrapping all sorts of clothes around the agitator. Have you tried washing similar items (rather than throwing in a variety of item types)? I run both small loads and full loads. Makes no difference in the outcome. The only thing that gets rolled up into a "cigar" is a large king comforter, and it does the same thing in the 520 dryer. A few tennis balls (each wrapped in a knotted sock to prevent dye bleed) helps a bit with the dryer rolling large items into a "cigar", but it's not a 100% fix. |
| Maybe my question wasn't clear. I don't wash jean, polos and towels in the same wash. The questions should have read.......What cycle for jeans? What cycle for polos? What cycle for towels? I don't have any trouble with things rolling up. I use dryer balls with the little nubs specifically made for the dryer. |
| Normal for all of those. StainAway for dirty rags. Bedding for sheets... I don't use any of the other cycles often. If anyone wants a bit more water in the wash on this model, choose the PreWash option... |
