Miele Electric Dryers - Does a reg. washer load fit?
Posted by lalitha (My Page) on
Mon, Mar 12, 12 at 14:58
Hi
A local appliance store sales guy told me just now that the main problem with Miele Electric dryers is that a typical load from the washer does not dry well in 1 shot. He said it is the same in both the bigger and the smaller machines?
I was specifically looking for the electric dryer instead of the gas dryer based on the feedback from this forum but this would be a big concern. Is this the case?
Lalitha
RE: Miele Electric Dryers - Does a reg. washer load fit?
I have no idea why your sales guy would say that. We bought our Miele electric dryer eleven months ago and it does a pretty good job. My only complaint is towels, but if I don't remove them as soon as the cycle finishes, the dryer will tumble them every few minutes, and after a while they are dry. The dryer also has a set 45-minute cycle one can use.
The negative: stuff sometimes isn't always 100% dry, like waistbands on my husband's slacks, towels, some knit cuffs on tops.
The positive: WAAAY quieter than my old conventional Whirlpool dryer, *and* because it errs on the conservative side of drying, I never have "baked" laundry because I've set a timer for too long.
I have no regrets about making the purchase.
If you fill your washer 3/4 full, which is how it should be filled, there is no issue. However, if you pack your washer tight with clothes, they will come out of the dryer wrinkled.
Also, you can set the dryer to More Dry/Less Residual Moisture and Extended Cool Down. With this, not only is EVERY item 100% dry, but my clothes are left insanely soft, fluffy and wrinkle free. And yes, I highly recommend Miele electric dryers, over Miele gas. It's only N. America that is offered gas. Miele shines with Electric!
What Mieles don't do well with is a load of stuff washed in a regular t/l machine. These clothes have a lot more water in them than clothes coming out of a typical Miele cycle. That would make it difficult for the dryer to do its job correctly. (The reverse, an HE f/l and a conventional dryer, works the equation backwards as the f/l clothes have less moisture so a much faster dry-cycle happens as more water is extracted in the washer due to higher rpm spins.)
L.
Ah! makes sense. Is there a visual marker on what is a appropriately sized load in the Miele washer? How do you know when the load is not too much?
