| So after getting burned big time on a pair of Neptunes, I made numerous phone calls to see about repair.
No one in my area uses the Tony Tool for bearing replacement, so the repair estimates were well over $400. Repairman after repairman gave their suggestions for a good all around replacement due to my financial misfortune.
Good luck to everyone on their decisions. Believe me when I say I went thru the wringer!! |
| A great big cyber hug to you, (((bookert))). It's no fun to go through the wringer. Here's hoping your new washer gives you years and years of great service. :) |
| mara 2008, Thank you! Yeah, no fun... I'm starting to remember how to use the old style machines. Happy Ground Hogs Day! |
| Hey, I almost forgot -- had a busy day today. Did the ground hog see his shadow? We've hardly had a real 'winter' this year at all. Detergent dosing -- do you buy HE or regular detergent? It seems the regular would be the right kind. Doesn't it have dosing directions on it? When I had traditional washers w/o detergent dispensers, I always started the water, then poured in the detergent, let it dissolve, then added the laundry. If I was washing in cold water, I used warm water to dissolve the detergent well, then switched to cold water. The easiest way to use fabric softener would be in a Downy ball (you could put any brand of softener in it). Do they still sell those? So glad for you that it has soak and prewash cycles! :) |
| A Kenmore 70 likely would have (or take) an agitator-mounted softener dispenser. It can possibly be added if the machine wasn't equipment with said dispenser at the time of manufacture. What's the specific model number? |
| mara, I have all HE detergent and put it in air tight containers upon purchase. The liquid is also put in different containers as I have some that pour better than most. =) dadoes, So any ideas on how much detergent is correct dosing? Thanks much! |
| The Downy ball opens in the rinse. I had one for years with traditional washers, and loved it. I used vinegar in it at times. Okay, I see your concern about dosing detergent. I guess my rule of thumb would be the amount of water the machine uses. If it's using twice as much water as an HE washer, I would most likely double the detergent dosage and check to see how the laundry turned out -- how well it rinsed, etc. HTH |
| I don't know if you've tried Sears detergent (or want to), but theirs is formulated for both HE and traditional washers -- same dosage for either. I saw in a local ad today that they have their detergent(s) on sale right now, Buy One Get One Free. The stainfighter formula (orange box) was pictured. I don't know if this sale applies to other formulas, or not. The detergent is also sold at Sears appliance stores, which are often more conveniently located than their big box stores. |
| Technically, Downy balls open during the first spin, but the ball is sitting with the weighted bottom toward the basket and the softener is held inside by centrifugal force. The open ball fills with water as the machine fills for rinse, the softener floods out and mixes into the load during agitation. |
| mara, Good to know about the liking of the Downey ball! =) dadoes, |
| The parts diagram @ SearsPartsDirect.com shows an agitator-mounted softener dispenser, so apparently one originally came with the machine but has been lost alongst the way. Or possibly it's listed in the diagram for reference as an option. It's part number 63594. Sears lists $10.47. PartsTap.com $6.99. You have the Downy ball, though, which works just as well. I'm not skilled at deciphering Kenmore model numbers for year of market introduction and feature set, but it does indicate a series 70 and of course manufacture source of Whirlpool. Cite the serial number, I can tell you the year and week of manufacture. |
| dadoes, Do you think the agitator mounted dispenser would work better?? It would be easier to use. |
| It'd be somewhat easier to use ... no need to fish the ball out, empty residual water, refill, pull up the stopper. But keep in mind that agitator-mounted dispensers MUST be rinsed often to avoid waxy yellow/pink/blue/green (as per the softener involved) build-up. Instruction typically advised to rinse after each use ... but after all loads for the washday are done is sufficient, rather than literally after each load. The softener dose should also be diluted with warm water to top-off the cup capacity. |
| dadoes, so the waxy build-up happens with an agitator mounted dispenser, but not in the Downey ball? Hmmmm why is that?? Just curious... I may just stick with the ball. =) I'm liking the ability to do a soak for however long I choose. A learning curve backwards if you will, but so far I'm pleased. Taking twice as long to dry clothes, but and I say but, they are SOFTER!! ?? |
| The Downy ball is actively rinsed by submersion and agitation in the deep rinse. An agitator-mounted dispenser simply drains the softener charge after the first spin, and doesn't get rinsed unless you do it. |
- Posted by curiousshopper (My Page) on Sat, Feb 18, 12 at 8:54
| When I moved into my house there was an 80s series Kenmore top-loader. The agitator dispenser was pretty gummed-up from years of use but I was able to clean it. When I took the cabinet off to do a repair I was not too pleased to see the same nasty build-up on the top of the outer-tub, above where the maximum water line hit. Another reason to use the ball. |
When I took the cabinet off to do a repair I was not too pleased to see the same nasty build-up on the top of the outer-tub, above where the maximum water line hit.Residue in that area is not related to what type of softener dispenser is used. |
