Amana Top Load Washer
Posted by Flyrite06 (My Page) on
Sat, Jan 14, 12 at 14:34
I have an Amana heavy duty super capacity plus top load washer. It is model# NAV335AWW Rev.27
The problem is the washer doesn't always drain during the spin cycle so the clothes are either wet or the tub is completely full of water at the end of the cycle. This is intermittent, sometimes it drains just fine. Also, if I open and close the lid during the spin cycle the washer will immediately begin draining. If the cycles have all completed and there is water remaining in the tub, if I select the spin cycle again it will drain the water out during that spin cycle. Any ideas or help would be much appreciated.
RE: Amana Top Load Washer
I would not be surprised if the belt is slipping. It's $24.00 to replace at the Repair Clinic website. While you are under the machine, check the pump to make sure it is spinning freely!
Thanks! I will try that and post the results.
I replaced the belt for 24.00 like you said. The pump spins freely. I have run 6 loads without a problem so it would seem that fixed it. Thank you!!
