New To Kitchens? Posting Pics? Read Me! [Help keep on Page 1]
Posted by buehl (My Page) on
Sun, Dec 16, 12 at 23:10
Welcome! If you are new to the Kitchens Forum, you may find the following information and links helpful.
The Frequently Asked Questions (FAQ)/Articles pages contain helpful information about how to navigate this site as well as the world of kitchen renovations.
The Kitchen Forum Acronyms will help you understand some of the acronyms used frequently in posts.
The Finished Kitchens Blog has pictures and information about many GW members' finished kitchens. Not only can you see them alphabetically, but you can also use the "Find-A-Kitchen" function to utilize several search options if you're looking for specific things like a kitchen w/a Beverage Center or a kitchen w/a mix of dark and light cabinets. Access "Find-A-Kitchen" via the via the menu bar at the top of any FKB page. Additionally, "Find-A-Kitchen" contains a link to "In-Progress Kitchens" for those members' kitchens that are not quite ready for the FKB. There is also a link to "Coming Soon Kitchens" for those kitchens that are ready for the FKB but have not yet been added. To access the "In-Progress Kitchens", the "Coming Soon Kitchens", and the "FKB Categories", see the links on the menu bar at the top of any FKB page.
The Appliances Forum is very useful when you have questions specific to appliances.
To start off the kitchen remodel process...take the Sweeby Test. Then, move on to Beginning a Kitchen Plan.
Other topics such as layouts, planning for storage, and stone materials are discussed in later topics in this thread. Even more information can be found by doing a search on the forum.
Tips:
  • Before posting a question, please search the forum. There's a very good chance someone has already asked the question.
  • When using the "search" function, be sure to use the search box on the bottom of the page, not the top!
  • Note, however, that you will probably have better luck searching if you use Google (or similar search engine) than if you use the Forum search function. When using Google, to limit your results to Garden Web, include the following in your search criteria: ***site:ths.gardenweb.com
  • In the Subject, the site changes the double quote used as the inches indicator (") to a single quote ('). We don't know why. To compensate, use two single quotes and it will appear as a double quote in the Subject. Luckily, the double quote works in the message box.
  • When composing a new thread, you have a couple of options:
    • Have replies emailed to you: check the box offering this option. However, you must have "Allow other users to send you email via forms at our site." box checked in your profile for this to work (see the "Your Profile" link at the very top of the page) [See the post later in this thread with the Subject: Getting Emails Sent To You...3-step Process]
    • Insert a link: When you "preview" your message, you will be provided with two boxes for a link...one is for the link itself and the second is for the name or description of the link.
  • When using the "Clip this post" option (far upper right corner of each post, small print), remember that only the current post is clipped, not the entire thread. Also, you are allowed a maximum of 50 clippings. Once you reach this max, you will no longer be able to clip or email posts.
How are the home page and the Forum organized? (based on the Kitchen Forum's FAQs entries)
  • The Kitchens Forum home page lists 30 thread titles, starting with those that don't yet have a response. After the unanswered threads, threads are listed in order of most recent response. That first page displays the last 2 hours or so of activity. (If there is no response to a thread in an hour or two, the unanswered thread usually starts to drop.)
  • Below the thread list are page numbers 1-67 for the total 67 pages of threads available -- capturing maybe 2 months or so of threads, less when the Forum is busy.
  • Below that (and at the top of the thread list as well) is a space for you to switch to the Conversations or Gallery "sides" - these are set up similarly but are not nearly as active.
  • Next down is a Search box -- very important! This is also the Search box you should use (not the one at the top of the page.)
    • Always refresh the page two or three times b/f assuming a thread has disappeared right after starting it.
    • As to searching...a thread will not be found doing a GW search for up to 24 hours after it has been started. This may seem too technical, but...searches are done against what are known as "indexes". Indexes use key fields/words to find things. iVillage only indexes threads once a day. So, that means that until your thread is "indexed", it won't show up in a search. If you start a thread just before the index is taken, you will be able to retrieve your thread by searching soon after creation. If, however, you start your thread right after the daily index, then you will have to wait almost 24 hours for the next index.
  • Next is a place for you to start a new thread. And finally there are some instructions and links at the bottom.
Kitchen Forum "Sides"
Discussions: This is the "side" you are on. It is for on-topic discussions concerning kitchens...renovations, use of, etc.
Conversations: This is the "side" where you can post off topic threads such as regional get-togethers and non-kitchen subjects.
Gallery: This is the "side" where members often post pictures...especially if you're posting a lot or a finished kitchen. (Note: This is where StarPooh, our FKB person, wants you to post your finished kitchen prior to having it added to the FKB.)
Again, welcome and good luck! The journey is wild, sometimes bumpy, but fun and very rewarding in the end!
Note: The links in this Read Me thread have been updated to reflect the new Finished Kitchens Blog (thank you StarPooh!)
How THIS thread is organized
  • Posted by buehl 7a, AHS 5/6 (MD) (My Page) on
To make this thread more readable and to make it easier to find a specific topic, I have created separate threads for each topic and just point/link to them from here.
We will continue to bump this thread, but not the other threads I created. Please, do not bump the "subject" threads I will be linking to from here. We do not want to flood the first page with all those threads. To do so would knock threads from members asking for help, etc. off the first page and would be counter-productive!
This post was edited by buehl on Sun, Dec 16, 12 at 23:11
Posting Pictures
    Sun, Dec 16, 12 at 23:12
Please click below to see the "Posting Pictures" topic:
http://ths.gardenweb.com/forums/load/kitchbath/msg0213484417254.html
Note that the topic in the link above describes how to post multiple pictures in a thread and does not use the GW "image" function. The GW "image" function is limited and in most cases is insufficient for our use.
This post was edited by buehl on Sun, Dec 16, 12 at 23:17
Layout Help
The following thread contains the information we need to help you find a layout that works for you and your family as well as how to draw up and label a floor plan.
http://ths.gardenweb.com/forums/load/kitchbath/msg010521247761.html
What are zones and how do you design with them in mind?
http://ths.gardenweb.com/forums/load/kitchbath/msg0508230128712.html
A piece of advice:
When you post a layout for comments, please do not take the comments you receive personally. Everyone here is trying to help, not criticize maliciously. We want you to have a kitchen that, in the end, functions wonderfully well and looks nice overall. This may mean that some of us may tear apart your layout and rebuild it to what we think will work better, but it's done with good intentions. We're not the best at just "validating" someones layout, we're best at critiquing!
I will warn you that most of us here are "function over form" (or "function first")...meaning we strive first for a functional layout and then fit the form or look around it. It is far easier to make a functional kitchen look nice than it is to make a nice looking but dysfunctional kitchen functional. So, if you are a form/looks over function person, be sure to state that when you post.
Some people here think "function over form" means that we want all kitchens to look the same....not true! What we do want is all kitchens to function well...which means that in 99% of the cases, the workflow is the same...so that will mean some similarities due to workflow. However, as each kitchen is unique, each will have its own unique quirks, etc.
In the end, remember this is your kitchen. You don't have to make any of the recommended changes if you don't want to!
[Note: If you're just posting for validation of your layout (i.e., you don't want comments that suggest changes), state that as well. If you don't, people will comment on it!
Warning: People may comment anyway, it's tough to let a kitchen go that you think is dysfunctional and will cause angst later...especially if it's not yet installed and we think we can help. Bear with us, we're just trying to help!]
The Next Step...Planning For Storage
Please click the link below to find out more about planning your storage, including where items are commonly stored.
http://ths.gardenweb.com/forums/load/kitchbath/msg010523449014.html
Posting a Link
Please click below to see the "Posting a Link" topic:
http://ths.gardenweb.com/forums/load/kitchbath/msg010437444278.html
Note that the topic in the link above describes how to post multiple links in a thread as well as describes how to use the GW "link" function. The GW "link" function is fine if you only have one link to post. However, if you have multiple links to post, the topic above will tell you how to do that as well.
Please click the link below to find out what to do to get follow-up posts emailed to you for a thread - either as the original poster or as someone who is "following" a thread.
http://ths.gardenweb.com/forums/load/kitchbath/msg0105243228880.html
Miscellaneous Information
Some information that may be of interest to you:
http://ths.gardenweb.com/forums/load/kitchbath/msg0105344116836.html
Contains:
  • Links from the "Read Me" thread
  • Pantries
  • Useful Information (NKBA links, Other Forums)
  • Helpful Threads (a myriad of past & present threads containing useful/helpful information)
  • Tile Information.
  • Stone Information (how to shop/test/install stone counters, how to remove stains)
  • Cleaning Your Kitchen
  • Custom Cabinetmaker Sample Agreement
  •  o
    Bookmarking & Saving Threads
    Bookmarking threads so you can find them later or saving them so you have them (and associated pictures) ''forever''
    http://ths.gardenweb.com/forums/load/kitchbath/msg0105292031876.html
    Note: As of Summer 2012, iVillage changed the thread lists & history functionality so that old threads can be resurrected. However, once a thread falls off of page 67, you will still need the URL of that thread to bring it back up. What has changed is that now if you bump the thread, it will re-appear in the list of threads.
    While this may be useful for some, it does have the potential for pushing newer threads with more recent information and those asking for help off the first few pages faster. I would like to ask everyone to use discretion in resurrecting old threads. Yes, some have a lot of useful information, but I would like to suggest we create a "Library" of such threads as part of the FAQ rather than bringing them back to the thread list.
    Eliminating Those Pesky Inline Links in Messages (Advertisements)
    How to Seal Your Stone
    Steps to sealing a stone surface, if it needs it.
    http://ths.gardenweb.com/forums/load/kitchbath/msg0105254810134.html
    Gel Stain Instructions
    RE: New To Kitchens? Posting Pics? Read Me! [Help keep on Page
    Caught you just before you snuck onto pg. 3!
    Bumpity bump.
    Bump it again to get it onto pg 1.
    Bump
    Bumpity bump.
    Sooo, do you gals want to pick a theme for this thread?
    Angie, you've been hard at work.
    Can we post art work? We don't have to continue but I will add one piece that has intrigued me from my art history class:
    Judith Slaying Holofernes (1614-20) Oil on canvas 199 x 162 cm Galleria degli Uffizi, Florence. (Wikipedia text)
    Emily Carr
    Landscape with Tree, c. 1920 - 1921 (another reference list 1917-1919)
    oil on canvas
    43.2 cm x 54.0 cm
    Collection of Glenbow Museum, Purchased 1956
    56.23.5
    Enduring! Oh, I love your theme and I LOVE your choices. I did not know either of these artists or their works. I would love to play along. I hope you don't mind, but my choices will be a bit more "conventional," (i.e., more well known) at least to start.
    La Grande Odalisque, 1814 by Jean Auguste Dominique Ingres
    The Louvre
    The thing I always really liked about Ingres is the difference between the background details and the treatment of the main subject. To me, I always thought this said (Ingres speaking here) "Yes, I can darn well paint photo realistic if I choose to: look at those curtains. However, I wish to portray my model in a different mode. It is not that I CAN'T paint her true-to-life, I want to emphasize other things."
    your pic didn't show so here it is. And that is a great little story to go along with the image. Thanks.
    So, lets post a picture of any art work (2-D or 3-D) and tell a little something about why the image is significant to the poster.
    Thomas Hart Benton
    "An outspoken populist, Missouri native Thomas Hart Benton used his art to extol what he saw as ordinary American virtues. His subjects ranged from colorful, rough-hewn Midwestern characters to broad epics of American life and history tinged with irony and social commentary." (Joslyn Art Museum)
    This is a copy of his work from the Joslyn Art Museum in Omaha web site
    Thomas Hart Benton (American, 1889-1975),
    The Hailstorm , 1940
    tempera on canvas mounted on panel, 33 x 40, 83.82 x 101.6 cm
    Gift of the James A. Douglas Memorial Foundation (1971), 1952.11
    Bump
    Enduring, thanks for fixing my Ingres link. I am not sure what the problem was -- I could see it on the preview.
    I continue to love your choices. As I say, I am less well-schooled and diverse, and for now I will stick to the more well-trodden paths.
    Here is Claude Monet's Impression, soleil levant (Impression, Sunrise). (1872, Musee Marmottan Monet). Obviously, this is not the best or most widely known of his works. The reason I chose it is that it was the painting that launched (and gave the name to) the Impressionist movement.
    The Nativity by Federico Barocci (1597, Museo del Prado, Madrid)
    Why I chose the subject should be obvious! I chose this particular work for its unusual composition.
    Nativity
    (Christmas bump!)
    Here is Angie's selection. Very beautiful Angie.
    ...He says, as he points, "look at the wondrous babe!"
    Thanks Buehl and Angie,
    How about this winter scene that I found. The image, text, and title are from this web source:
    http://www.kunsthaus.ch/wintermaerchen/gallery.html
    "Pieter Brueghel the Younger: Winter Landscape with Bird Trap, 1601
    Oak, 39 x 57 cm, Kunsthistorisches Museum Vienna, Picture Gallery
    This is the first independent winter landscape in European art. Unlike Pieter Brueghel’s celebrated Hunters in the Snow, this painting was never part of a series of the Seasons. And there is no reference to a religious, mythological or historical story. This is interesting and important because for a long time landscapes served exclusively as backdrops: for biblical stories, for scenes featuring classical gods, or for depictions of important historical events."
    Lovely Monet above got me thinking of more, but not yet. First a little contemporary sculpture:
    "Nomade," by the Spanish sculptor Jaume Plensa, a 27-foot-tall hollow human form made of a latticework of white. This resides at the Pappajohn Sculpture Park in Des Moines, Iowa.
    Overview:
    Within:
    Bump only, so as to keep the thread from getting bogged down with photos. It has occurred to me that over 100 images would be a little much:)
    Maybe every now and then do a picture.
    OR, we could do links to great art.
    Here is a link that might be useful: Monet's
    Bump
    Wassily Kandinsky, a Wikipedia entry for this artist.
    Here is a link that might be useful: Wassily Kandinsky
    bump
    bump
    bump
    I'm baaaaack!
    Would you believe we have a Plensa in my town, too!?
    Bumping early to say, "yeah, but your's has got a leak" ;)
    What a gorgeous picture of the lake, sky, and statue!
    Ha ha on the leak comment! Yours is very large compared to ours... maybe ours "leaked" away.
    bump!
    Bump
    Bump to keep you off Pg. 4!!!!!!!!!!
    I don't know why I like Barbara Hepworth so... something to do with the negative space and the organic forms.
    Great image of Hepworth, I love sculptures capacity to work with space and movement.
    From the Guggenheim Museum website:
    "When Constantin Brancusi moved to Paris from his native Romania in 1904, he was introduced to Auguste Rodin, the French master sculptor who was then at the height of his career. He invited Brancusi to join his atelier as an apprentice, but the younger artist-with the confidence, stubbornness, and independence of youth-declined, claiming that "nothing grows in the shade of a tall tree." Brancusi rejected Rodin's 19th-century emphasis on theatricality and accumulation of detail in favor of radical simplification and abbreviation; he suppressed all decoration and explicit narrative referents in an effort to create pure and resonant forms. His goal was to capture the essence of his subjects-which included birds in flight, fish, penguins, and a kissing couple-and render them visible with minimal formal means."
    Brancusi's "Muse" (La Muse), 1912. White marble, 17 3/4 x 9 x 6 3/4 inches (45 x 23 x 17 cm). Solomon R. Guggenheim Museum, New York, Photo: David Heald
    bump
    I saw this IRL today!
    Thomas Gainsborough. Mary, Countess Howe, (ca. 1764. Oil on canvas. 95 x 61 in. Kenwood House, English Heritage; Iveagh Bequest).
    Lovely, looks like she could step off the canvas and be our contemporary.
    Bump
    bump
    Bump
    This was also at the exhibit I went to the other day (Joshua Reynolds, Kitty Fisher as Cleopatra Dissolving the Pearl, 1764, oil on canvas, 56 1/8" x 44 1/2"):
    Kitty Fisher as
    What really struck me was how Reynolds captured that faraway look in her eye, even though we can only really see one of her eyes!
    This post was edited by Angie_DIY on Thu, Jan 10, 13 at 13:14
    Bump.
    This post was edited by Angie_DIY on Thu, Jan 10, 13 at 13:15
    Bump
    Bump again
    Dumpy bumpy
    BTW, enduring, I really liked the Brancusi. So interesting that he had the opportunity to work with Rodin, and yet took such a different tack. Thanks for sharing that!
    Bump
    Thanks Angie, I'd never seen the "Muse", but it caught my eye when I was looking for another of his sculpture's that I like.
    Buehl, love the snow sculpture! Who did it?
    Bump!
    Snowman Bump
    Bump
    Bump
    Buehl, I think I like "Snowman-2" even better.
    Bump
    Bump
    My goodness, weekends are busy!
    bump
    later I might look for art to post
    My lake was frozen today. It's colder than usual.
    Bump.
    The Penitent Magdelen (Antonio Canova, 1796. The Hermitage Museum, St. Petersburg.)
    This post was edited by Angie_DIY on Mon, Jan 14, 13 at 17:14
    Wow this forum moves quickly!
    Moving right along!
    WOW, what a pose! Looks like complete resignation.
    In any case, Bump!
    Bump again
    bump
    Horizontal horse's or mule's skull with feather, Georgia O'Keefe (1936, Milwaukee Art Museum)
    which lives in here:
    Bump! (get off of pg. 3!)
    Enduring: oh my gosh! I was just looking over the art we (especially you) chose for this thread. I just noticed that the work (which I loved) by Thomas Hart Benton (with whom I was unfamiliar) was done in tempera! That is amazing and cool!
    Bump
    How about this Grant Wood Angie? Look at the oak tree in the foreground.
    Grant Wood, The Birthplace of Herbert Hoover, 1931.
    Of note this was a commissioned painting by Iowa businessmen as a gift to president Hoover. But when it was presented to him, he rejected it. The source I am getting this information from (DM Art Center) states that "the figure in the center of the paing points to the small cabin in which Hoover was born. But Hoover 'did not approve of the painting in which the actual cabin is obstructed by a house that was not there at the time of Hoover's birth' ".
    Another comment taken from the Des Moines Art Center source. "In her book, My Brother, Grant Wood, Nan Wood relates that the critics 'couldn't decide whether Grant was glorifying or satirizing President Hoover. Considering the artist, most of them decided it was satire.' "
    Another American artist I did not know anything about! I think the trees are hysterical; give it the shape of an oak (foreground) or maple (?) (background), but make the leaves markedly out of scale so you can show the leaves, too. It works!
    Thanks for the nice picture and story.
    Oh, you know Grant Wood....
    .....look familiar?
    American Gothic, by Grant Wood, oil on beaver board (whatever that is)
    Created in 1930 and sold to the Art Institute of Chicago in November of the same year. Information from Wikipedia.
    Kind of in your face :)
    Bump
    Naughty naughty thread hanging out on page 3 !!
    I have always liked this ever since I saw Sunday in the Park with George in the theater in London. This is one of Georges Seurat's most famous works, and is an example of pointillism.
    A Sunday Afternoon on the Island of La Grande Jatte
    Artist - Georges-Pierre Seurat
    Year - 1884-1886
    Type - Oil on canvas
    Dimensions - 207.6 cm x 308 cm (81.7 in x 121.25 in)
    Location - Art Institute of Chicago
    http://en.wikipedia.org/wiki/Sunday_in_the_Park_with_George
    Angelia and Deedles thanks for posting art.
    That bustle really pops out doesn't it, in the Georges Seurat painting.
    And Deedles what is that? Your imagination? He's wearing Converse BB shoes.
    Bump
    No art here but have enjoyed your postings. Thanks.
    Bump to help get this back to pg 1.
    Enduring, you are right. I didn't recognize Grant Wood, but should have!
    bumping early to thank "willtv" for that crazy painting. Thanks for your input. That is some image. It looks like it could be some massive fresco, tell us more if you will, Will.
    bump
    Bump
    Enduring, Yes it is a fresco by Diego Rivera. One of my favorite artists.
    Here's another.
    I'm attaching a link to a Google image search for more of his work.
    I don't know who first thought to include art in the "bumping program", but it's really a great idea.
    Here is a link that might be useful: Diego Rivera Images
    This post was edited by willtv on Mon, Jan 21, 13 at 15:19
    Thanks Will, I will take a look.
    The art was my idea. Angie has always had literary ideas. So I thought since this is such an artful site, image art would be a good thing, to go with the poetry she started on the last thread. The down side, that I realized quickly, was that the images really slow down the loading of this important thread.
    So for the sake of the impatient I propose that we post the smallest files we can find or create :)
    Girl with a Banjo, Mary Cassatt, 1893-94, Pastel on paper:
    Just kidding.
    This post was edited by enduring on Mon, Jan 21, 13 at 20:12
    Well, perhaps the idea really came from Breezy, with her "musical bumps." Although I guess we were doing lyrics before that, and I forget what else!
    I do like the art a lot. I also like the idea that we CAN post a picture, but don't have to. I enjoyed the poetry thread immensely, but I admit I was getting a little tired of "having" to find a new poem each bump.
    Nice to have you as a "bumper," Will.
    Bump
    Bump.
    bump
    William Michael Harnett
    This post was edited by willtv on Wed, Jan 23, 13 at 8:39
    Bump
    I should visit these more often. Deedles, I think that's one of my favorite artists, Edward Gorey. The rest of you probably know him probably from the intro to Mystery!
    From an Amazon review of the Gashlcrum Tinies:
    "A is for Amy who fell down the stairs. B is for Basil assaulted by bears. C is for Clara who wasted away. D is for Desmond thrown out of a sleigh..." The rhyming couplets of this grim abecedarian are familiar, of course, to devotees of macabre humor, but the darkly crosshatched drawings are (as Poe put it) "the soul of the plot." Several years went by during which The Gashlycrumb Tinies: Or, After the Outing was not available in a small hardcover edition like this one, which is the true format for Edward Gorey's specialty, the adult picture book. (For those who wish to share the gloom there's a 10-copy assortment with The Curious Sofa.)
    Here is a link that might be useful: Link to book
    Bump
    Bump
    My goodness -- are you still around, NTK?? I thought you got resolved long, long ago.
    Lame, GW!
    Bump
    bump
    This is from a VERY interesting art project on contemporary body image. The artist photoshopped classical paintings, giving the depictions of Venus that we are all familiar with a "modern" idealized body type. Pretty revealing. In this one, and all that are on the link below, the modern one is shown first followed by the original.
    Here is a link that might be useful: Body image art project
    Fascinating Angie, my DH and I were looking and we both think the modern take on the painting is weird looking.
    Willtv, the second Diego Rivera is stunning. It looks like an adobe room painted top to bottom. DH said "Cool!" to both Riveras
    Bump
    Fascinating Angie, my DH and I were looking and we both think the modern take on the paintings in the link are weird looking.
    Bump
    Enduring, I definitely agree, the skinny versions of Venus look weird and not terribly attractive. However, I do think the photoshop artist did not overly exaggerate. That is, I could easily imagine the skinny versions gracing, say, a perfume or eyeshadow ad in a magazine. I cannot say the same for the original versions.
    Bump
    bump
    Frida Kahlo (1907-1954), Autorretrato con monos, 1943 (Self-Portrait with Monkeys, 1943) oil on canvas 81.5 X 63 cm.
    Pg 3?!?!?! You naughty thread!
    Wow, you move fast!
    Holy moly!
    Incredible! On pg. 3 again.
    Enduring, Here's another.
    Bump
    On pg. 3 yet again!
    boot. Thanks for the beauty...
    boot -- thanks for the beauty
    Bump
    bump -- moving at the speed of sound!
    Maybe supersonic, actually!
    Bump,
    SNOW DAY, YAY!!! NO WORK FOR ME!
    Pg 3 AGAiN?? Bad thread!
    Bump
    bump
    ooomph
    Bump
    bumpity
    bumpity bump!
    bumpity bump bump!
    Bump
    A piece of wood art! Would you look at those drawer tolerances!
    And a little soapstone!
    I've added the link to my soapstone sink progress.
    Here is a link that might be useful: Finally the Plans for Soapstone Sink Taking Shape!
    This post was edited by enduring on Sat, Feb 23, 13 at 1:34
    How do you get so far down on page 2? Up you go...
    That is some sink, enduring. Can you make me one and mail it to me? ;-)
    Bump!
    NO NO NO, not ever another sink (I don't think anyway). I can't believe I am almost done! Angie you have been a real cheer leader with this sink project. I want to thank you for all the encouragement you've provided.
    Buehl, I love the "flake". It is truly one of a kind.
    go !
    Did you make the sink, enduring? So nice!
    Aliris, yes I made the sink. It was a real adventure, thanks.
    And now for the bump
    Bump.
    It is easy to cheerlead for such a wonderful project!
    Bump.
    Bump!
    Bump
    I love the beautiful sink made by an amazing Enduring.
    Bump.
    bump please.
    What happened?
    Earlier today enduring's sink pic was right side up. Now it is upside down on my iPad. Anyone else see it this way??
    This post was edited by tea4all on Mon, Feb 4, 13 at 21:54
    Tea4all, turn your ipad around;)
    its right side up on my macbook pro
    This post was edited by enduring on Mon, Feb 4, 13 at 21:58
    Oh dear me!! I am so embarrassed. It is really apparent I am a newbie on the iPad.
    Hopefully You all had a good laugh! ;)
    Tea, did it work?
    Bump
    edited to add LOL, for tea4all!
    This post was edited by enduring on Tue, Feb 5, 13 at 7:22
    Nope Enduring. The sink pic is upside down no matter which way I turn the iPad. However, it is just fine on my Mac. I thought it was just a fluck yesterday and figured things would straighten out today.
    It's been a crazy day with our senior dog at the vets. I got on GW for some sanity tonight but "New To Kitchens.." just continues the craziness. I think I should cut my losses and go read a book. ;)
    Big BUMP to get this baby off of pg 3.
    Bump
    Bump
    Willem Claeszoon Heda
    "Still life with oysters, a rummer, a lemon and a silver bowl" (1634), oil on canvas, Rijksmuseum, Amsterdam
    Please Note: This thread has reached the upper limit for the number follow-ups allowed (150). If you would like to continue this discussion, please begin a new thread using the form on the main forum page.
