| I'm trying to plan out my cabinets and I have limited options. I want to know if those of you with Blanco Silgranit sinks (especially the 10" deep ones) have any room in the sink cabinet for a trash can. I'm trying to design a trash cabinet pull-out, but it sure would make my design better if I could put the trash under the sink. I think there might not be enough room under the sink. Thanks for your help. I'm looking at the performa medium 1 3/4 sink. |
| I have a Kohler farm sink, set on inset cabinets, so my doors are onliy 17 1/2 " tall. I got a double trash can pull-out from Container Store tnat works perfectly!! Nancy |
- Posted by tag_singer (My Page) on Sun, Dec 16, 12 at 19:56
| Hi cathy725, I have a similar 10" deep Silgranit sink. A double bin pull-out certainly won't work because of the drain pipes, but a bottom mount like the Rev-A-Shelf linked below may do the trick, provided you just use the front bin. I measure a 13" clearance from my drain pipe to just inside the cabinet door (11" on the side with the garbage disposal.) Height from the bottom of the sink to the cabinet floor is 19 1/2". You may have to call to get more detailed specs, but a bottom mount looks to me like a viable option. Good luck! |
Here is a link that might be useful: Rev-A -Shelf bottom mount trash container
| Thanks everyone! Badgergal--what is the capacity of your trash can? |
| We have the Blanco Silgranit D (I forget the size but it was the largest to fit in a 30" cabinet). We tried a couple different pullouts for the right side of this cabinet and then DH made a very simple drawer for me which has worked well. We store the trash bags behind it. This is a slim 10" square trashcan but we have a second, larger one in the prep area, as well as two for recycling. Good luck! |
