| I've noticed I have a rough spot next to the faucet at the kitchen sink. I think it's minerals from standing water. It doesn't look bad (yet) but I'd like it to be smooth like the rest of the counter. Also, I just had the norovirus and am trying to disinfect before company comes. I've read that it is a hard virus to get rid of, but the kids' plans are made and they are coming. Norovirus may be the gift that keeps on giving, but I'd just as soon spare them the intimacy with a bathroom that I've just had. The fabricator told me not to get bleach on the counter, but I've read that is the only thing that is effective. cdc says to use a bleach/water mix to clean. Is that diluted enough not to harm the granite? |
- Posted by debrak_2008 (My Page) on Fri, Dec 21, 12 at 16:42
| I don't know about barkeepers on granite. How long have you had your granite? I don't recall it being installed that long ago. I get some mineral buildup on our bathroom granite but it takes awhile buildup. I use a razor blade to scrape it off. I use the alcohol/water mix that many on GW do on my blackish granite (bathroom) as it does not have or need a sealer. I do not use the alcohol mix on my white diamond aka BA (kitchen) granite. The installer said some people like to use the alcohol mix to disinfect but to use it sparingly on granite that has/needs a sealer as the alcohol will eventually eat through the sealer. Also just remember this... the installer gave me super fine SS to use if I ever need to get some gunk off the granite. He said it would not hurt the granite or the sealer but would get it super clean. Thats all I know. hth |
- Posted by may_flowers (My Page) on Fri, Dec 21, 12 at 17:05
| Don't risk it! My fabricator used it to remove epoxy from my Caesarstone, on the advice of the Caesarstone sales rep, and it dulled the surface. Caesarstone wouldn't do a thing about it and they had to pay for a new slab. Quartz has a resin binder, and BKF is an abrasive. |
| NO, good chance BKF will etch or leave residue on the stone. Get some plain steel wool--I think I usually use 000 (can also use 00, which is coarser, and 0000, which is finer--I use whatever I have handy. Try it out first on in an out of the way area). I buff away mineral deposits or errant marks that resist cleaning with alc-water spray and a microfiber cloth. It also buffs away rings (water deposit) from coffee cups or glasses. |
- Posted by mountaineergirl (My Page) on Fri, Dec 21, 12 at 18:16
| I wouldn't use the kind that is like comet, but the kind that's like soft scrub should be ok. If it doesn't scratch/dull a stainless steel sink, could it really hurt a rock? |
| I don't know about the mineral deposits, but a VERY dilute solution of bleach and water will kill most everything. I found a link, they recommend 1/3 cup bleach per gallon of water for countertops. Honesty, the more dilute solution of 1 Tbsp/gallon would probably do the job and would be safe for most everything. |
Here is a link that might be useful: Disinfecting for Norovirus
- Posted by Momto3kiddos (My Page) on Fri, Dec 21, 12 at 22:27
| I have been on this forum too much when I read your subject line as "can you use beekeepers friend on granite?". I thought, what? She has marble! I have gotta get out some more! |
- Posted by srosen (mail@stoneshine.com) on Sat, Dec 22, 12 at 0:55
| Barkeepers friend is a stainless steel cleaner formulated with some fine abrasive and 5-10% oxalic acid. Should be ok on granites as they are acid resistant and hard enough to take a very mild abrasive. Itshould do well removing mineral deposits near faucets. Always test first because some granites which are resined or dyed can be affected by acids. I like to remove mineral or calcium buildup with a single edge razor blade(held at a 45 degree angle) and MB-3 or diluted vinegar(test first) Always test new products in an out of the way spot or a sample piece just to be safe. As far as disinfecting 1.5 oz of bleach in a quart of water sprayed on the area and left to dwell for 7 minutes should do the trick. Vinegar is also a good disinfectant as well on granite that you have tested it on. I like 3% volume hydrogen peroxide-use it on your countertops and let it dwell for 7 minutes than wipe off. Is a great disinfectant and is non-toxic to all. Is 100 % biodegradeable as well. Regulated disinfectants are toxic. |
- Posted by lazygardens (My Page) on Sat, Dec 22, 12 at 6:32
| The recommended bleach formula for labs is 1/2 to 1 cup of bleach to one gallon of water ... spray it on liberally, let it sit for 10 minutes and wipe it off. That should not be strong enough to hurt granite. But it will kill Hanta virus, HIV virus and many other nasties. |
| Thanks all. I was afraid to try the barkeeper's friend and I'm glad I didn't. My granite has been in about a month, and the rough spot is also a really dark place in the granite and may just be rough. I'll try steel wool or razor blade on it though. I don't think the bleach solution I mixed was even that strong lazygardens. It was whatever the cdc recommended and I don't remember it now. Didn't hurt it though. |
