single bowl sink drain location
Posted by ctycdm (My Page) on
Wed, Dec 26, 12 at 11:59
Pretty sure I've got our new sink narrowed down to two : Blanco Silgranite Super Single in Either the 'Precis', or the 'Diamond'. The main difference being drain location. Precis drain is centered left to right, towards the back of the bowl. The Diamond drain is offset to the right and centered front to back. Having never owned (or used) a single bowl before, what are pros and cons of each set up? Being a symetrical person, I like the looks of the Peecis better, but does the offset drain of the Diamond make it more user friendly?
RE: single bowl sink drain location
Here's the one I thought I would like...
Here is a link that might be useful: Precis super single
Here's the other choice I recently found. I'll be under mounting either one...
Here is a link that might be useful: Diamond super single
This post was edited by ctycdm on Wed, Dec 26, 12 at 12:12
I have an off set drain in a Kohler cast iron. I love it. It gives you more usable space in the sink.
Fact of the matter is you will be very happy with either one. You can't make a bad choice between these 2.
If you get the Diamond and your plumber can get the plumbing all nice and tidy on that same side you will gain some under cabinet storage space. If this is not new construction and you don't want to move plumbing that probably won't happen.
When you are washing a large roasting pan in the Diamond it will not cover the drain and that is seen as advantageous. If you use the sink grids, you won't cover the drain anyway.
I love my Blanco Silgranite sink, I thought about both of these but ultimately went with a double bowl. I will never by another sink that is not Silgranite.
My sink's drain is smack in the middle. Although offset is considered more efficient or hip or something, I have never thought, oh drat, how much better things would be if mine weren't in the middle. Just having one large bowl and a grid (yes, I've finally embraced the grid) has made kitchen life so much better.
One thing to consider in pondering the under-sink architecture: the loss of usable space with a center drain is somewhat (but not entirely) mooted if you do not plan on having a garbage disposal mechanism below it.
Without a GD you can use something called (I think) a handicapped drain line which allows you to shift the position of the trap apparatus from directly under the drain to a back corner, freeing more center space if needed. This should be checked with your local codes but it is permissible in mine and I plan on using it because I already had my sinks purchased before the possibility of an off-set drain even crossed my horizon. And I have no GD as we have an old-fashioned septic system, so none is possible. I've never had a GD, so I didn't really comprehend the concern for under-sink space until I saw one in a show room.
If I was considering a GD, then the offset drain would be tempting.
I never have a problem with my large single bowl with multiple uses (I don't understand the need for two bowls.) I hand wash all my dishes and kitchen stuff (no DW) and I never find a conflict with clean/dirty/prep water usage. It's a big sink - I just move the faucet over to where I need it. I stack my used utensils (or soak in a bowl) during cooking and then wash it all after the meal.
One thing I like about the center drain as this is the default position for the faucet, too, which minimizes splashing when turning it on.
HTH,
L.
I looked and looked for a large single bowl sink with a side rear drain. The Rohl's original fireclay farmhouse sink met that criteria, but it wasn't deep enough for my cookie sheets to lie front to back and DH wssn't sold on a farmhouse sink. There might have been a couple of stainless ones, but if so they were too shallow and one was too deep (12 or 13"). We wound up with a center drain, and I think it actually worked out for the better.
When you have a large single bowl, you have the option to set things on either side of the drain and still leave the drain open. A side drain is good for a smaller to mid-sized sink where you pretty much have to dedicate one side to soaking or stacking, leaving the drain unblocked and possibly having an open area for use on the side.
We do have a disposal as well as 2 DW connections and an instant hot tank. We also have cleaning supplies as well as trash and recycling under the sink -- all in a 36" cabinet. I had to study the details and threaten the installer if he didn't pay attention and do it like I told him (he had already messed up the prep sink and potfiller installations and had to make adjustments), but it all fit and we got the best use of the cabinet space as well as a very functional sink.
I don't understand the drain and faucet placement supposedly being better if the same. We had more of a splash with the offset drain and faucet in our prep sink until we changed the faucet and got one with a deeper reach so the water stream would hit in front of the drain opening. When the other faucet was turned so that water hit the drain opening, the water would hit the disposal guard and splash out.
I think my grandmother had a single bowl sink, so I'd used one, but DH and I were both unsure about living with one. Neither of us have missed the double bowl and I'll be happy to not have one of the standard types again.
Thanks for all the helpful replies! Some great points brought up here. I think I'll stick with my first choice, and go with the Precis (center drain) We do have a GD, but because our sink sits diagonally in a corner, farther back and in the center is probably the best place for it. Also, I noticed the Diamond has slight curves on each side of the bowl, to me this looks a bit more contemporary, which our kitchen is far from...
