| Hello
I just had new countertops and backsplashes installed in my kitchen. I did not change or add any outlets or light switches The granite fabricator / installer cut the rectangle holes for the outlets and switches in the granite.
See attached photo
Thanks |
- Posted by cloud_swift (My Page) on Sun, Nov 18, 12 at 23:07
| Here's what ours look like. I'm not sure I understand your concerns entirely, but it seems like your outlet boxes may be set too deep compared to the granite front. When they are screwed all the way into the boxes they may be recessed too much below the granite surface which won't work with a wall plate on top of the granite. Some wall boxes have a depth adjustment. With the box at the right depth, it shouldn't matter whether the ears rest on the granite or not. |
- Posted by jerzeegirl (My Page) on Sun, Nov 18, 12 at 23:36
| I wonder if you can use an "Outlet Extender". It's a box that fits over your existing box and raises it making it flush with the surface of the wall. I haven't had the opportunity to use one yet so I can't tell you anything more than I know it exists. You might want to google outlet extender and see if you think it will work. |
| I think I may be missing something obvious, but in case I'm not..... cloud_swift, I think that setup works for you because you have those really nice Columbia Gorge stone outlet covers that attach with magnets. (Which are wonderful, btw. I hope I can afford to get some made when all is said and done.) If you had used outlet plates instead I think their top screws would have run into the stone right behind those top screw holes. In murphysf's case the covers need to attach with screws. For those Decora outlets there are 2 screws that go into the small threaded holes at the very top and bottom of each outlet -- the one in the middle between the two "ears" on each end. (I just noticed the red arrow pointing to it at the top of her photo). In that photo, the topmost screw won't work because it will run into the granite right behind the threaded hole. I see three options there: For the bottom, if jerzeegirl's "outlet extender" idea doesn't work you could try just putting a small scrap of stone, wood, or whatever behind the bottom set of "ears" to hold it the right distance out from whatever is behind the stone. Laura, insomniacal and long-winded |
- Posted by cloud_swift (My Page) on Mon, Nov 19, 12 at 10:56
| Laura, I think you are right after re-reading the OP's post Drilling out a bit more of the granite, very short screws or screw-less switchplates seem like the only alternatives that will work. Hmm, I don't think we told our stone fabricator that we were going to be using screw-less switchplates. IIRC, we made that decision when we were ordering the custom plates after the granite installation was complete. We couldn't order before then because we needed the remnants from the stone to send to Columbia Gorge. It seems we could have had the same issue. |
