This post was edited by gwTamara on Mon, Nov 26, 12 at 23:03
- Posted by desertsteph (My Page) on Mon, Nov 26, 12 at 17:02
| thx! |
| Getting the following error notation when attempting to edit: (using Windows IE) Internal Server Error Please contact the server administrator, root@astrology.com and inform them of the time the error occurred, and anything you might have done that may have caused the error. More information about this error may be available in the server error log. |
| I will make an inane, vacuous comment that will later blossom into brilliance. If it hasn't, editing didn't work. Oh well. This was on a Mac with Firefox. |
This post was edited by marcolo on Tue, Nov 27, 12 at 13:55
| Hi Co-Co, I edited using IE 8.0 without an error message. However, for those using IE, there is an issue with html tags showing up in the preview window. What browser and version are you using? |
| I edited this using iPad with iOS6. Worked beautifully. Ow how about a spell checker :) Editing twice on the same post works |
This post was edited by lalitha on Tue, Nov 27, 12 at 2:50
| I was successful using iPhone and Mac with mountain lion! Thanks! |
- Posted by lazygardens PhxAZ%3A Sunset 13 (My Page) on Tue, Nov 27, 12 at 9:38
| Testing the edit feature. Using Firefox on Linux, it appears to work. |
This post was edited by lazygardens on Tue, Nov 27, 12 at 9:39
| Original comment. Snow Leopard. Edited: Rejected...need to change subject line. |
This post was edited by linelle on Tue, Nov 27, 12 at 9:53
| I wonder if editing your post will make the thread go back to the top of the list or not? Evidently not! I just edited, and the post is still in its position as dictated by the post after this one. |
This post was edited by Angie_DIY on Tue, Nov 27, 12 at 15:47
| I successfully edited a post (obviously in a different thread) which contained both a pic and a url. Everything come through just fine, yippee! What might not be so useful in the up-to-date-world is that I'm on Win XP SP3 with IE 8 on the 'old faithful' laptop until I find the right hybrid tablet/laptop. cheers, |
| mtnfever - you are not alone...I am on windows 7 but no plans in the near future to update to the a tablet here..... EDIT: in fact I'm on my DESKtop computer right now. Slow as molasses compared to the laptop but still works. Firefox is the browser in case that matters to GW. |
This post was edited by Autumn.4 on Tue, Nov 27, 12 at 17:23
| I'm on Windows 7, IE9 with the error message posted above. Will try to edit with another browser. okay, adding this with Firefox. Looks much different than when I tried editing with IE9 (ie: looks totally normal here, tons of html codes in IE9). What is solution (delete all the codes?) |
This post was edited by Co-Co on Tue, Nov 27, 12 at 18:48
| There appears to be a defect... We cannot edit posts on the thread linked below.The Subject is truncated and the message is rejected.Only the Preview button appears. I think it's the quotes in the subject - the subject is truncated after the "7". I was able to successfully edit on a different thread just now. Browser:Firefox 17.0 Editing Post: Two defects!Note that the thread's subject was also cut off in the link. Three defects...I cannot edit a post too soon after I edited it a previous time. The message is rejected and since I cannot change the subject when editing a post, I cannot use the workaround of changing the subject. |
Here is a link that might be useful: Subject of thread:27
This post was edited by buehl on Tue, Nov 27, 12 at 23:20
| I just tried to edit from that post and encountered the same issue. I've notified tech and I suspect it's the quotes in the subject line as well. Stay tuned! |
| You rock buehl, you're a real detective! |
| Should be working now. It wasn't the quotation marks, but there was an issue in the subject line. Give it another try and let me know if you run into any further issues. |
| On other boards that allow edits, there's often an unwritten rule of etiquette for the poster to explain the edits, usually at the bottom, e.g., Edited: to fix typos Edited: to clarify upper cabinet height etc. It can be very helpful to those following a thread and wondering what changed in a post they already read in unedited form. |
| Great idea linelle. Do you just use the etiquette without prompting or is one prompted to post the reason? |
| Enduring, I've never seen a prompt to explain the reason for editing a post. I picked it up after seeing others do it. It's just a courtesy. |
