Wax paper left marks on my wood table...HELP !
Posted by MIssyV (My Page) on
Thu, Nov 15, 12 at 15:03
ACK!! I baked some cookies today and let them cool on wax paper on my wood kitchen table. When I cleaned up from baking I found nice little round prints from where EACH cookie cooled.
Has anyone ever encountered this? Is there anything I can do to remove them? There are 2 and a half dozen of them :)
RE: Wax paper left marks on my wood table...HELP !
I have an old solid maple table that gets rough treatment. I set down coffee cups and wet plates and anything else you can imagine. I'll get rings from cups and glasses, but then they disappear. I don't know where they go. Sounds like your wax paper melted a bit from the cookies and ended up on the table. Surely it's just sitting on the surface and will eventually wear off.
That's awful, I'd be in distress too! Maybe do a Google search and see what you can find out. Like linelle suggested, do you see what looks like a waxy residue or are they white scorch marks?
If it is wax from the paper use some paint thinner.
If it is a heat mark into the finish it may fade.
two words: wire racks.
If it's wax which sounds likely
Two options - brown paper and an iron on mild heat-
or benzene (or lighter fluid)
can be a little tricky depending on how deep into the wood but I'd expect not that far unless you burned the cookies.
Likely will wear off too.
Then get a better sealer and as noted wire racks make for better cookies.
Should have been clearer- put down brown paper, then run the iron over it- not too hot or long- pick up and see if you won
I've heard that Howard Restor-a-Finish is a good product. It removes heat and water marks.
http://www.howardproducts.com/prod-restor-a-finish.php
If it is wax residue, I've used a paper towel & warm iron similar to jakuvall's recommendation. Paper towel soaked up the wax great.
hth
