Sealer left brown marks
Posted by piggyspen (My Page) on
Fri, Oct 26, 12 at 16:21
The picture is of my kitchen after the countertop was installed but before sealed. I have blue pearl granite and used AquaMix Penetrating Sealer. I asked the installer if I should seal and suggested sealing with any sealer every six months. So I sealed it.
When you get certain light, there are brown "stains" in the granite. I have used several things, including Acetone on the granite, but nothing seems to budge it. I have called my installer sevral times, but so far no luck on getting him back to help me with this. Any suggestions out there? I want this beautiful shine and clarity back!
RE: Sealer left brown marks
The first thing I would do would be to get to the sealer manufacturer. Do they have hotline? Next would be the vendor. I'm not even sure your type of granite even needs a sealer, by the way. My stone was sealed at installation 7 years ago. I found GW a year later and resealed. I used what you used and it took major elbow grease to remove the haze. However, there were no brown streaks, and I have no idea what would cause them. My stone is allegedly porous, but I just resealed it for the first time in 6 years. This time I did not use Aqua mix. Also, try the Stone Advice Forum. I'm on iPhone. Please excuse typos.
Blue pearl generally doesn't need sealing. You should remove the sealer and see if the stain goes away.
weissman, what would you suggest removing the sealer with? I have tried several things, Acetone being one of them. Didn't do it! That is what I am trying to find out -- what to use? I have even contacted the sealer maker but not heard from them yet.
Acetone is what's usually recommended - are you using pure acetone (as opposed to nail polish remover :-). Checking with the sealer manufacturer is the right thing to do.
Usually, the sealer that you used will dissolve the sealer that is still on the counters. So you can reapply the sealer and use a bunch of elbow grease to remove the re-emulsified sealer. Steel wool, scrubbing, actual acetone, and follow up with pure Dawn and hot water usually does the trick. Polish dry with some cotton towels like you would a fine automobile.
