| If the wall mounted hood needs supports in back to attach it to the wall and I'm not putting in a backsplash all the way up to the hood, will the bottom back edge look weird sitting ~3/4" off the wall? If anyone has pictures of such an installation, I'd appreciate seeing them.
Thanks!!
| I'm having trouble picturing the supports. Is this something that comes with the hood and is meant to mount on the wall, then the hood mounts to the supports? Because 3/4" seems like a lot of space for even a backsplash to cover. Or is this just the blocking (plywood, usually) necessary to hang it safely? If this is something that has to go in front of the wall, perhaps you can have a carpenter craft a small "frame" around the back of the hood to hide the supports. You could paint it the color of the wall and it should fade away. Can you attach a picture or a link to the hood and it's schematics? |
- Posted by breezygirl (My Page) on Tue, Oct 2, 12 at 18:35
| Do you mean just a stainless hood? Mine doesn't have any blocking; it attaches directly to the wall. I do plan to tile the wall eurosplash style though. Even if I didn't, I don't think tile would look funny near the hood. Maybe your hood is different? |
- Posted by laureng_123 (My Page) on Mon, Oct 8, 12 at 14:58
| Sorry I really didn't do a good job of explaining my situation the first time. When installed flush against the wall, the top corner of the hood is set back almost an inch from where the cabinet trim will end. I'm attaching a picture of what it looks like now. I am considering having the hood pulled forward an inch from the wall so that the top corner is flush with the trim. I'll have to put 1" thick wood behind the hood to mount it to the wall, but I can't figure out how that is going to look underneath the hood along the back wall. And my installer wants an extra $150 to modify it, so I'm not sure if it is worth it. Should I leave it as is? Anyone else run into this situation? |
- Posted by laureng_123 (My Page) on Mon, Oct 8, 12 at 15:23
| I changed the subject line to be more accurate. |
- Posted by breezygirl (My Page) on Tue, Oct 9, 12 at 1:03
| You cannot change the title of the thread once you've posted it. Your title change only applies to the individual post in which you change it. Thanks for the further clarification. I would leave it as is. Make sure to cleanup the paint job on the sliver of drywall showing between hood and soffit. Once the whole room is done and you're not nose to nose with that area, I doubt anyone would notice. |
