painting cabinets myself HELP
Posted by trijar (My Page) on Tue, Oct 20, 09 at 9:18
| Does anyone know of a good website or know where I can get instructions on how to paint cabinets? I have an island and a cabinet which holds my double oven that I would like to paint a distressed black. I would like to do it myself. Any suggestions or tips of what to do or not to do would be greatly appreciated. My cabinets are solid oak, i believe. |
RE: painting cabinets myself HELP
| The good news is, that I believe painting a darker color is going to work in your favor! I painted my oak cabinets an off white. It was a bit of a challenge, but with lots of patience you can pull it off. There are excellent resources on the painting forum. Someone over there even has a pamphlet that they will send you. I used an oil based paint, but there is a product called cabinet coat, which is latex based. Both of these methods will have pros and cons, so do some reading. If you don't mind seeing the grain of the oak, then you've got it made. I did not want to see the grain of the oak and I used a product to fill the grain: pore-o-pac. I needed 3 coats to level out the grain. This was A LOT of work, but really worth it. Good luck, and get over to the paint forum and do some searches! Just remember, the paint job's success is really dependent on the prep work. Don't cut corners. |
| trijar, there has been an earlier post on using General Finish Gel Stain in Java color. I don't know how to find it,(sorry) but maybe someone else on here will help you out. |
| http://ourcreativelife.blogspot.com/2009/05/steps-to-painting-your-wood-cabinets.html http://www.doityourself.com/paint/paintkitchencabinets http://owcl.blogspot.com/2006/05/cottage-kitchen-cabinet-makeover.html this is detailed instructions for above. What steps were involved in painting and "antiquing" your kitchen cabinets? A The first step was to clean the cabinets thoroughly with a spray on degreaser. I sprayed my cabinets and let sit for a bit before wiping off and repeated this step a couple of times. I was amazed at how much dirt and grease dripped from my cabinetry! It's important that as much of this grime as possible is removed so that the paint can stick well. After cleaning, I sanded thoroughly and then wiped my cabinetry down so that no sanding dust remained. A note about painting: All the paint that I used was Latex (water based). I used a good quality brush for all of my painting. If hand brushing isn't your thing, you may want to look into a a good quality sprayer. I've never used one and hear that some people love them and some hate them. Also, it is very, very, VERY important that you let each coat of paint dry and cure thoroughly between recoats. If you don't, the fresh layer of paint could reactivate the last layer, resulting in an awful, paint peeling and bubbling nightmare. I painted my cabinets in the heat and humidity of summer and sometimes had to let nearly a week pass between coats because the paint was taking forever to dry and then cure. It was well worth the wait time, though. Next, a couple of coats of a good quality primer, inside and out. You'll want to use a good "bonding" primer. Then I added an off-white basecoat, inside and out. (American Tradition: Homestead Resort Parlor Taupe, Satin Finish). After the basecoat, I applied four or 5 coats of red (Waverly: Cherry, satin finish) The interior was left off white, though the shelves were painted red for interest. I distressed the edges by sanding lightly down to the off white basecoat. Next I brushed on a dark brown glaze ("Raw Umber" translucent color glaze from Lowes) then wiped it off, allowing the glaze to settle into crevices. The next step was to very gently and sparingly drybrush on a couple of colors here and there. I chose a bluish shade and sage green. This gives a "layered paint" effect. Note- the next step is NOT recommended and was experimental on my part- proceed at your own risk:) The result was fine but it was frustrating to try and achieve just the right sheen - and with LOTS of elbow grease. I would instead ask a professional about the right kind of protective finish to use, if any. I do happen to know that the Minwax brand clearcoat Satin finish produces a HIGH gloss shine, so unless you are going for that look, avoid! -Lastly, for added protection, I added a thin coat of Johnson's wax paste, let it set, then buffed it all out leaving a soft sheen. This step will need to be repeated every few months or so. A year later and the paint finish is holding up great! No chipping or peeling to speak of! After getting a quote for $7500 to reface, I'm digging through my 'how to paint yourself' files that I saved! Good luck! Trish |
| Trijar, if I were doing it I would use Milk Paint, which adheres to sanded wood like nobody's business, no primer required, completely safe for your family and is absolutely gorgeous when it's burnished and antiqued. It actually sinks into the wood, so there's no danger of chipping like with plastic (latex or acrylic) paint. And you can choose whatever protective clear coating you like, from organic oil to superindustrial poly.
(I know I sound like a commercial for milk paint, but I've just started using it on furniture and it's utterly amazing stuff.) |
Here is a link that might be useful: milk paint
| I love this blog. I also have very dark wood oak cabinets that I am painting BM White Dove. I wanted the grain to show through. I primed 2 coats with Zinnzer oil based primer. I am using BM Aura now, again two thin coats. I'll let that cure for 30 days and then I'll use a non yellowing finish coat. Minwax and SW both make one. I'm in progress but happy with the results so far. I should be posting pictures in December. I'm using a mix of my old cabinets with new ones too. |
Here is a link that might be useful: easier link
Circuspeanut...
| I thought milk paint was for unfinished wood. Or can I use it on my oak cabinets if I sand them? Confused. I love the look and idea of milk paint THANKS. |
| I've used it on wood over another finish and unfinished wood, and even on resin. They make an additive you can put into the milk paint that makes it stick to non-wood or finished wood - you still need to do a bit of sanding first to roughen the surface. The difference is that the paint is opaque over another surface. To get the classic translucent look with a slight hint of woodgrain, you would have to sand the cabinets down to the bare wood. Depending on the cabinet style and what's already on there, sanding all the way down could be easy or hard - tedious, but well worth it for the great finish. And realistically, you'd spend just as much time putting on smooth coats of primer for latex or oil paint. It's hard to capture with my camera, but maybe you can see the difference here: dark gray milk paint over a cheap dark-brown resin mirror frame:
very light gray milk paint over bare unfinished oak (this was my weekend project this week):
close-up:
cp...thanks...
| great projects... ok so these cabinets are mine...and i'm picturing in my head a more cream than yellow color. I have been afraid of chipping as my trim has all eventually chipped a little throughout house ... we just had it all repainted so hopefully it will be good for at least a couple years.
so you think I can sand far enough down? and how much grain? i'm not a huge fan of the grain....competes with floor grain... Trish |
| If you don't want the grain to show, I think that makes your life a lot easier. You can just scuff sand the whole surface, then use 2 or 3 coats of milk paint with the additive, then a clear topcoat. If you have any similar finished wood sitting around (old shelves or trim? or even a cheap small shelf from a box store), you could give it a quick sand with 120 or 180 grit sandpaper, grab a bag of the paint and experiment with your technique a little first. I know I must sound like a fanatic (!), but I truly recommend the milk paint so strongly for DIYers because it needs less prep & is much more forgiving than latex paint, doesn't show paintbrush marks, and adheres really well. And the totally matte surface is easy to burnish ("age") before topcoating. Some folks layer two different colors to get more antique effect. The great thing is that you can mix colors until you have the exact color you want, or use one of the gorgeous premade colors. The yellows, whites and creams are lovely:
Have fun! :-) |
| Since we're talking about milk paint - can do either of you ladies know whether your can use it over bare mdf? My unfinished cabinet doors may end up with mdf panels, and I was hoping to use milk paint (for all of the wonderful reasons you described above). |
Thank you!!
| I feel a little more empowered now. I can do it...I can paint. I think I'll start with a hutch in my dining room I've always wanted to paint red....FUN. I remember reading & I'll have to find someone who did her island with milk paint...red then black to antique. What's the best place to order from? Thanks again. :O) Trish |
| Trish -- you can order directly from their web site, or you can find a local art supply or paint dealer who carries it (link below). junicb -- I don't see any reason not to use it on mdf. You won't get a grain and it might take more coats if the mdf is super absorbent, but if it's unfinished, the paint should stick and react just like on wood. Test on a spare piece of mdf first? Have fun! I could paint everything with this stuff, it's so enjoyable to play with and so different from regular paint. (but don't let spills dry because you'll never be able to get them out later!) |
Here is a link that might be useful: milk paint dealers
dealers / mdf
